Just joined the forum, and this is both a valid discussion question, and a test that I am doing this forum right.
I just acquired a C&C 30 and the fuel cutoff / engine stop cable is frozen. The pervious owner says he never used it, and used the throttle to stop the engine. First question is just curiosity, followed by soliciting opinions on what I'm thinking about doing.
Does anyone use the "engine stop" for normal shutdown, or do you consider it an emergency fuel cutoff? Based on what I learn here, after I fix the frozen cable I am thinking of adjusting the throttle so that it does not stop the engine, but reduces it to an idle, and relying on the "engine stop" for normal shutdown. I figure that will result in fewer accidental stalls, but I am a virtual novice (I had a Catalina but that was so long ago I don't remember much) so am open to opinions.
