Cutless
Jan 30, 2012
1,123
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
How to change cutless on a boat with no strut? Options: remove stern tube altogether? Remove shaft?
Erwin
capta
Jun 4, 2009
4,772
Ask the boatyard for help. They should have the special tools to do the job swiftly and properly.
Jan 30, 2012
1,123
Still one wants to know. Mostly because no boat yard within many miles
Hunter 34 Alameda CA
Without removing the shaft I would guess? There is some exposed. Would that be enough for a pipe wrench or large locking pliers (vise grips)? If you can get it to start rotating it may work out. Clamp on to it close to the stern tube where you could lever it out a bit at a time.
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
I bet you'll be removing the prop and shaft and use a puller or cut the cutlass bearing lengthwise. It looks like the bearing is the 1st step up from the prop shaft.
bletso
Aug 20, 2013
106
Globe 38 PCB
Mine had me stumped as well. Had 4 bolts. Removed them and nothing. I finally figured out it was screwed into the shaft log. The bolts kept it from un-screwing itself! cutlass
3,541
My Albin Vega has the same type of arrangement, only the bearing isn't screwed into the log like @bletso. I just remove the prop, remove the two retaining bolts, and the bearing comes right off.
Likes: Justin_NSA
