Coolant in Engine Pan
RoyS
Jun 3, 2012
1,742
Had a similar engine pan mystery for years and just solved it yesterday. Every now and then would find a spoonful of liquid below the engine. Liquid did not appear to be coolant or oil or diesel, so assumed seawater. Re-bedded everything in the area and never discovered source, until yesterday. It was a small leak under the engine in the bilge pump hose which passes through the engine pan area. The leak was only active while the bilge pump was operating which was seldom. My mystery solved.
JRT
Feb 14, 2017
2,060
So went out and replaced the last 2 OEM hose today. The small elbow at the front of the engine and the formed large hose to the heat exchanger. Wasn't hard but used a bunch of towels for all the coolant spilling. After burping the system it seems like I'm in good shape.
136
Catalina 2004 310 (Hull #250) BC
For the record, the coolant recovery hose attachment hole to the manifold was indeed blocked completely on my engine. 1/8" drill bit here I come. Add another item on the engine annual check list.
JRT
Feb 14, 2017
2,060
No coolant under the engine after a week sitting since those last 2 hoses were replaced. Motor ran stong as always and after we got back in the slip looked dry still.
