Concrete Docks
3,811
Pearson/ 530 Strafford, NH
Hi all,
I was recently talking to our marina owner about the winter storms and damage to the docks. I asked him if concrete docks would be a better option. His reply was that they would damage the boats more being less forgiving. Does anyone share that same concern. I've visited other marinas and have tied up to them. Seems to be a trade off for a more secure dock.
All U Get
May 23, 2004
3,319
I would not want to dock at a dock with concrete docks. Think about how abrasive concrete is. It would grind the gel coat right off of a boat with a few touches.
Wood is forgiving. My favorite docks are the floating docks with wood or fau-wood tops.
Dec 2, 1999
15,184
The concrete docks that I have seen have wood on the edges to attach the rubber baby buggy bumpers to. They make a far superior dock to anything that I have ever seen. If you step on them with bare feet you do not get splinters.
I think that there are lots of advantages but I must assume that they cost a lot more too.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Concrete is great for a breakwall or breakwater, but overkill for regular docks.
Most marinas and yacht clubs in Canada have figured out how to make docks that can survive winter.
Nice to hear Canada has figured out docks. Only ? I have is when are you going to figure out cleats??? :):):) Instead of those raised wooden 2 x 2 s???
Steve Dion is right about wooden edges to our concrete docks. Ours rarely (never say never!) get blown away. Where they do, on a somewhat regular basis like in hurricane alleys, it seems appropriate to use wood.
I've been in one marina for 12 years with wood and this one for 13 years with concrete. Concrete is so much more stable in our environment (your mileage may vary!;)).
We have floating concrete docks here in Greenport at the Michell Park Marina. I've tied up to them many times. They are very stable and dampen waves nicely. They are sturdy to walk on. If they are properly made there is wood trim or rubber like padding where a hull would hit. You use bumpers like any other marina tie up. I don't really see a down side - they're not like a concrete pier. I don't think they remove them in the winter but our winters are not what a Maine winter is.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
He's right, floating docks are far more forgiving to the boats, especially in areas with larger tidal ranges, like Maine. Floating concrete docks are very expensive and heavy.
The major problem with floating docks is what happens if the storm surge is higher than the maximum height on the pilings the floating docks are secured with, since they can then float free... which is bad.
It also is harder to tie a boat to fixed docks so that the boat won't hit the dock when the tide shifts. But fixed docks are less susceptible to damage from winter storms and ice.
Rick D
Jun 14, 2008
7,193
Good Docks
Yea, concrete floating docks are great. More expensive in the beginning but far less maintenance. Most of the Mexican and Central American marinas are going with concrete. Bellingham is the big dog in the concrete dock business, at least in the west. Still, they are not maintenance free. There is wood used as ties and on sides which eventually require replacement. I know of concrete docks which are more than 50 years old and still functional. I know wood ones too. Most wood ones are disintegrating tho. The wood ones of that vintage are either trashed or replaced one float and finger at a time.
Here's a link to Bellingham if you are interested
http://www.bellingham-marine.com/company/index.aspx
Ross
Jun 15, 2004
14,693
Re: Good Docks
With concrete piers you use industrial strength fenders, AKA truck tires.
Jun 6, 2006
6,990
I Love Concrete
It is truly a maintenance free substance. Liquid rock that takes ANY shape you want then turns to solid rock FOREVER.
Course I might be biased, I'm a civil engineer. We build things that don't move.
Oct 22, 2008
3,502
No, it's not... New England winters take their toll on concrete... it does require maintenance.
PaulK
Dec 1, 2009
1,447
Sabre 402 Southport, CT
How well floating concrete docks work for you may depend upon how calm your harbor is. They are heavy, and large waves will get them moving, with the resultant chafing on each other and (despite wooden edges and bumpers) and on boats. We had a storm here last week with 75mph gusts raising 2' waves in our harbor which is usually flat as a millpond. Lines chafed through on more than one boat, and they got some nasty scratches. On the other hand, I think the club purchased the docks back in the 70's. With just standard maintenance - replacing rubber bumpers or dinged wood, anything that lasts for 40 or so years is a good thing.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I've had the pleasure of staying at Camanchee Cove marina in St Augustine and the concrete docks were pretty robust and looked like they would last forever and wondered why you don't see more of them.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I have to agree with Sailingdog
If you believe this...we have a bunch of badly degraded concrete bridges to sell you up here in New England! Of course that might be due to lack of maintenance. :doh:
May 21, 2009
360
Hunter 30 Smithfield, VA
(The major problem with floating docks is what happens if the storm surge is higher than the maximum height on the pilings the floating docks are secured with, since they can then float free... which is bad.)
.... On the other hand, if the surge is high enough to float the docks off pilings, you're looking at a 10 ft surge. You're going to have boats with lines going down below the water to the submerged fixed docks. Can't get to your boat to adjust the lines when the docks are submerged and that could be really bad too, particularly in a narrow slip if your overall line length is short. And I've seen power boats get blown under the dock when the tide was low and then fill and sink as the tide came in.
I just had to make that decision here. I'm at Smithfield Station which has floating docks. During one really big storm they nearly overtopped. But the thought of how the boats were doing at the fixed docks where I was considering moving made me decide to stay here.
Rick D
Jun 14, 2008
7,193
Must Be A Left Coast / Right Coast Thing
Floating docks are the norm here. Here's a couple of photos that indicate their durability in our conditions. The first is in Mexico, 25 year-old Bellingham docks in an area with a nasty surge. Could use some maintenance, but holding up well. The second is in Marina del Rey. Bellingham also, but 50 years old; should be replaced sometime soon, but did well. The third is in my current marina, five year old concrete docks. Having been on wood docks for 34 years and concrete for four and on a marina board, I'll take concrete.
PS: when we had the recent Tsunami, I was a little concerned. At high tide, there are maybe four to five feet of piling exposed. The tsunami event was about four feet according to a live-aboard neighbor. That's probably two feet in each direction. Still, I'm glad it wasn't worse or at an extreme high tide.
3,811
Thanks all,
In the past we've tied up to all sorts of docks. I'll do some unsubstantiated surveying this summer as we cruise. I just hate running into big lumber, especially at night, from some old dock.
All U Get
Jul 1, 2004
567
Hunter 40 St. Petersburg
Lots of relative pros and cons for sure
I've lived on each type during the past ten years. I loved the concrete floaters. But I can assure you that they don't have to float off the top to be a problem. Just ask the folks at the Vinoy in St. Pete.
I live on concrete fixed now. Although I like them fine I harbor no illusions about what would happen if Anthem got up on them in a storm.
You pick your poison.
