I need advise on how to remove the compression post on a Pearson 35. My plan is to removed the bulk heads, because I see no other way to remove the compression post. I think it comes out aft. I was remodeling so one its out of the way with 4x4 support on the forward cabin .
I plan to loosen the rigging and raising the cabin carefully from below with structural support.
I was also wondering if the aluminum post could be fixed without removing it by cutting the base and attaching a new one.
Your advise will be appreciated.
Thanks,
