C
Chuck Kretschmar
I have recently bought a 1988 Catalina 30 with a tall rig. I am trying to locate the second water tank. The prior owner had carpeted the interior so I have not yet gotten into the hatch in the cabin sole that is just below the dinette table. The owner's manual shows two water tanks plus the hot water heater. I located the hot water heater under the port dinette seat next to the holding tank. The main water tank is under the forward v-berth. I have two water filler caps on the starboard side of the boat. So, where is the second water tank? I've tried tracing the filler hose but I can't follow it under the cabin sole. Any suggestions? (It's not behind the port settee.) Also, if there are two tanks, is there a valve to a switch between the two tanks? If so, where is it located?
