Hello! I am considering a 1986 H23 but the trailer has no brakes. It's the original Kens Welding trailer. I live in New York State and the boat/trailer is registered here. NYS law says if the trailer weighs less than 1000lbs no brakes required unless the maximum gross weight exceeds 3000lbs . If the trailer is over 1000lbs brakes are required. My understanding. Is all trailers must be safety inspected annually. I assume if brakes required and I have no brakes,automatic failure. Get caught and a pretty stiff fine. As you know the H23 weighs 2450. The trailer I believe Is at least 900 lbs so brakes will be required. I actually feel the brakes are a good idea. If so can they be added to the trailer pretty easily by a pro (not me) or is a new complete axle with brakes needed. Thanks!
