Buying a Hunter 23. No brakes advice
Nov 9, 2022
48
Catalina 30 Cayuga Lake, Ithaca, NY
Hello! I am considering a 1986 H23 but the trailer has no brakes. It's the original Kens Welding trailer. I live in New York State and the boat/trailer is registered here. NYS law says if the trailer weighs less than 1000lbs no brakes required unless the maximum gross weight exceeds 3000lbs . If the trailer is over 1000lbs brakes are required. My understanding. Is all trailers must be safety inspected annually. I assume if brakes required and I have no brakes,automatic failure. Get caught and a pretty stiff fine. As you know the H23 weighs 2450. The trailer I believe Is at least 900 lbs so brakes will be required. I actually feel the brakes are a good idea. If so can they be added to the trailer pretty easily by a pro (not me) or is a new complete axle with brakes needed. Thanks!
I would suspect trailer brakes would be a sugar coated project for most trailer shops.
Just check around. You want to be sure before you become their Sugar Daddy.
Nov 9, 2022
48
Thanks! I luckily have a trusted local trailer shop. So you think they can be added without a new axle or worse? ( I'm mechanically technically challenged)
I do not have a definitive answer. Either way you bring in the trailer and drive away happy. It will likely include a controller in your truck cabin. They are a pretty common fix to trailers not designed for them.
Nov 9, 2022
48
I have a controller and all wired up for brakes. I tow a 15 ft travel trailer. Towed it to Rocky Mt Nat Park this past summer. I can tell you they came in handy more than once on that 3500 mile round trip. I might tow this boat this summer to take my 7 yr old granddaughter for a sail. You may think I'm crazy and I am, but I can sleep free at truck stops and shower too!
p.s. I owned an H23 about 15 years ago and after sailing about 2 years, reluctantly sold it and gave up my love of sailing. My life is changing and I'm getting back to sailing before I get too old... Did I have brakes back then. No. Do I remember why not? No. We lived in Massachusetts maybe different law?
-na -NA Anywhere USA
You need brakes on that trailer as the center of gravity is very high causing swaying. Now retired but I was the top dealer for that boat. Get brakes and if you have to move it without brakes, there are three suggestions. First do not go over 40 mph. Secondly stay far back behind the vehicle you are following. The third thing is to increase speed to pull out the swaying of the trailer and then brake slowly and I mean slowly.
Being a Ken’s Trailer, I would suggest a new axle with brakes.
JBP-PA
Apr 29, 2022
712
Jeanneau Tonic 23 Erie, PA
Yes, brakes can usually be added to a trailer without replacing the axle. You can get either surge brakes that do not need a controller or electric brakes. If you are not mechanically inclined, having a shop do it is easier. I have had difficulty getting a trailer mechanic to install brakes, they don't seem eager to do the work.
I know the axles put on that trailer plus the age. New axle. Make sure fenders are secured to make sure they are not falling off.
I personally knew ken
48
Dave: your response is much appreciated and I will follow it. If you have any idea what replacing the axle, wiring the trailer might run I can see how my local quotes compare.here in upstate NY. My first was a quick est. at $1000. I tow a small travel trailer and have a controller. Thanks again!
May 24, 2004
7,202
CC 30 South Florida
Was that the NYS regulation in 1986? It was common to find 22-23' sailboats with a single axle trailer and no brakes. States are passing trailer regulations based on highway speeds and I agree that speed is a consideration of whether the trailer is adequate. It perhaps may not be adequate for 70 MPH but if the intended use is for 45MPH roads it could very well be. There is also the tow vehicle to consider, we used to trailer a 1987 Starwind 223 with a single axle trailer without brakes, the whole setup could have been close to 4,000 lbs but we towed it with a Lincoln Navigator and had no problems braking and could hardly tell we were pulling it at highway speeds We did have a problem with having to make frequent stops because of overheating bearings likely caused by the heavy load on a single axle at highway speeds (65 MPH). We trailered up and down the East Coast, Long Island Sound, Chesapeake Bay, the Outer Banks, The Florida Keys, etc. We considered adding an extra axle but never got around to it. You can control sway by placing the majority of the load ahead of the axle and increasing tongue weight with an adjustable height hitch ball mount. Must the boat be on the trailer when you take it for inspection? Listen if you want to get brakes get them, they make sense and insurance companies nowadays are looking for every angle not to pay on claims.
What no one recognizes is the fact the hunter 23 is a wing keel that sits high up on the trailer causing the trailer to sway as the center of gravity was high up as well. This is based on personal experience as a dealer. When I submitted plans to Hunter for the 23.5, I was involved designing the trailers from that point on. I was Hunter’s overall largest small boat dealer
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I would not have tried to tow my 23 without the trailer brakes, at least not very far or fast. Mine had surge brakes, and I replaced the system myself. New coupler with surge hydraulics, new brake lines, new brakes. The brake shoe assembly bolts to the plate on the end of the axle, and I assume you'd need new wheels with the brake drum. As Dave noted, may (or will) need new axle. If I recall, without a new axle, the parts were around 300 or 400. I'm guessing you'd want electric brakes, I assume these are more $$. I'd guess 1000 or so seems reasonable for a shop to do it. I also replaced the bearings, as they were corroded.
Nov 9, 2022
48
Thank you all for your advice. I've decided to pass on this particular boat and will continue my quest better armed with the advice you gave. Have a wonderful , joyful Christmas!
p s in one of the archived replies to a post I found this quote:. "Continue your research, your boat will find you..."
May 24, 2004
7,202
CC 30 South Florida
The Starwind 223 had a fixed keel center board combo. It had about a 2ft draft and sat high on the trailer. We never had problems with sway by placing the outboard and most movable weight in the floor of the cabin ahead of the axle and adjusting the tongue weight. I remember those boats were sold back then with single axle trailers. A strong tow vehicle is required for highway speeds.
@Benny17441
If you put the Starwind 223 beside a Hunter 23 wing keel Hunter on a Ken’s Welding trailer, the Hunter 23 sits higher. However, I disagree with your assessment on the Hunter 23 sitting atop of Ken’s Welding trailer without brakes no matter how it is positioned. As I said my comments are based on knowledge and experience, not on supposition.
Originally brakes were not considered nor an option! The 23 was forward on the trailer as far as it would go on a Ken’s trailer with a single axle. I was on US 220 north of Greensboro, NC which was a heavily traveled road towing my a 23 to my dealership at Smith Mountain Lake near Roanoke, VA.
A tractor trailer southbound on US 220 went left of center line striking the port side of the boat causing it to sway violently. I was behind other traffic trying to brake from hitting traffic in front of me with the trailer and boat swaying violently which caused me to loose control. The boat came loose from the trailer with both that crossed over to the other side of the road. My car too crossed over too in front of oncoming semi’s missing from being broadsided by a tractor trailer rig by 5 feet. Boat and trailer were totaled. Car sustained minim damage. The following day, Hunter was made aware of the swaying issues of a hunter 23 wing keel on a Ken’s trailer by another dealer and I too. Brakes were immediately offered as an option but in my case it was standard on all trailers. Shortly after that, the foremost sailboat trailer designer, Ron Frisosky, called at the request of Hunter. Ron was also a Catalina representative. I learned so much about designing sailboat trailers from Ron.
Without brakes on either 1or 2 axles on a Ken’s trailer, it can and will sway. Most people do not know what to do when a trailer is swaying. ALL THIS IS BASED ON EXPERIENCE AND WHAT I LEARNED FROM RON FRISOSKY. I nearly could been killed!!!
May 24, 2004
7,202
CC 30 South Florida
Dave, I don't question your knowledge about the Hunter boats, but with all due respect trailer sway happens due to a load imbalance. There are two types of load imbalance 1) improper static balance with too much weight behind the axle and 2) motion induced imbalance due to swerving, heavy braking or road conditions. Speed is also a multiplying factor in the severity of trailer sway. The load's center of gravity sitting high on the trailer can also add to motion imbalance, but only when triggered. There is no way you can account for or prevent trailer sway when sideswiped by a tractor trailer, but that is not the trailer's fault nor the height of the center of gravity of the load. A balanced trailer is one where the majority of the weight is ahead of the axle and the corresponding tongue weight is attained with the rails parallel to a level road surface. The rule of thumb on tongue weight is 15% of the total trailer and load weight. I fully agree that no one can go wrong by adding brakes or making any modifications to improve trailering safety. I repeat that we trailered that Starwind boat for thousands of highway miles without incidents nor worry. Your incident must have been terrifying, but if because of it you got Hunter to add brakes and improve the trailer, more power to you.
I was talking about the Ken’s Trailer only. My experience was based on my experience as I was the top selling dealer. I use to refer to it as Ken’s Whopper. I tried everything as you mentioned even with the help of the most experienced sailboat trailer designer, Ron Frisosky. He taught me well.
As for the tractor trailer hitting the towed boat the driver fell asleep at the wheel coming left of center striking the boat.
in addition most drivers with a swaying trailer tend to brake making matters worse. I took 3-4 days of instruction to teach my customers how to trailer, launch and sail their new boat. That included to accelerate to pull the swaying out and then gently brake and stay far behind the vehicle in fryof them.
As for Ken’s Whopper trailer, I improved the trailers after that delaying delivery of several Hunter 23. If there were any issues with Catalina ,Hunter and Precision, the owners came to me for help. You have no idea what I contributed to this industry. Think twice befor you challenge me again
