Ok, so I've searched the archives and haven't found enough info on the process required to replace the starboard bulkhead in a C 27. Have an 87 that I need to repair. Anyone care to share the step by step process for removing the existing starboard bulkhead? The port side will be down as well but it seems fairly straightforward. I'd like to remove them intact to be used as a pattern. Don't want to remove the head or anything else if it doesn't have to be. Help!
Steve
Steve
