This question, or series of questions is perhaps most appropriately directed to MainSail, since he has demonstrated mastery of the art of gelcoat polishing; but, I'm happy to benefit from anyone's experience on this topic.
I have a 1984 Catalina 36, the gelcoat of which is in reasonably good shape, above average for a 24 year old boat, in my opinion. However, it is dull, like a flat finish, in many areas, and gets dirty quickly, and stays dirty.
This year I had the boat yard polish the topsides and decks. I am not sure exactly what they did, but it looks very clean. I assume n acid wash (On and OFF), machine buff, and some wax. They did a nice job, and apparently spent a lot of time on it, but they stopped short of the wet-look that I hope to achieve.
I read MainSail's tutorial, available here:
http://www.sailnet.com/forums/gear-maintenance/42309-ryobi-vs-makita-vs-poliglow-3.html#post301656
I looked at his pics, here:
http://www.pbase.com/mainecruising/buffing__waxing
So, I went out (online) and purchased the Makita 9227. The kit I got came with two nice pads, a twisted-yarn wool (white) pad, , and a wool/synthetic blend (yellow) pad, plus a nice tool bag ($177 with shipping and insurance on eBay).
I also purchased a kit of the Lake Country 8.5" CSS foam pads on autogeek.net; yellow, orange, white, black, and blue pads, backing plate and two microfiber towels, pad cleaning stuff; and got a pad cleaning tool, too.
Polishing "product:" I have on hand, from previous reading on this topic, On-and-Off Gel, West Marine Extra Duty Rubbing Compound, Meguiar's #2 Fine Cut Cleaner, and #9 Swirl Remover, 3M Finesse-It II Finishing Material (39003). I have a can of West Marine Carnuba Paste Wax.
A note on these: Meguiars confuses me a bit, but it appears that #2 and #9 are intended to be complimentary products; the instructions on the containers refer to each other; this isn't on their web site, though. 3M is euqally confusing to me, although they seem to have a more straight-through product progression, from
I have 3M wet or dry sandpaper in every grit from 220 to 2000.
Also on hand, several and various microfiber cloths, spray bottles, and a couple of 5 gallon buckets.
So, in summary, the context is that I want a "better than new, wet-look finish" everywhere there is gelcoat - topsides, and decks, including all cockpit surfaces (the C36 has a big cockpit). I would like to have the best looking boat in the boat yard. I would like to do it intelligently, and as quickly and efficiently as possible, in a "workman-like manner." I want it to last, and will maintain it. I also hope to be able to do it with what I have on hand already; but I will get more if I'm missing something key. For example, do I need a "glaze?" Do I have one?
The questions are:
1. Where to start?
2. What is the recommended polishing schedule?
For question 1, I know what to do if I was starting from a heavily oxidized hull with no wax on it - which would be to wash it well, hen etch it (acid wash, On-and-Off), wet sand up through 2000 grit, then on to machine polishing (this is where it starts to get fuzzy for me).
Given that I've had some work done already, where should I jump in? Should I "test" with the Finesse-It II, and back down to coarser grits and pads if it doesn't work?
For question 2, what progression of product and pads is recommended to get to the wet look, once I've jumped in and caught up to the right spot? I mean, this pad, this product, then this pad, this product, and so on.
Bear in mind that varying parts of the boat may be at different stages of polish. I imagine I'll have varying "starting points" around the boat.
Additional thoughts: for minor gelcoat repairs, such as for broken-through voids, and filling of screw and connector holes, where and how on earth can I have gelcoat material tinted so it matches the boat well? Right now it looks like a bright white spot repair: not good; and finally, what should I do about the molded-in, contrasting color non-skid areas on deck? I want them to look good and clean, but not wet, and certainly not slippery.
Hints and tips on buffer technique are welcome, too; although I consider myself handy, I've never polished anything with a pro buffer.
Thank you all very much in advance for your input.
jv
The questions are:
1. Where to start?
jv
