Beneteau 473 - Help Bilge Pump Selection
Mar 20, 2018
7
Beneteau 473 Alameda, CA
Hello,
Our survey for our recent purchase of a 2002 B-473 identified that we should increase the volume of pump out capacity in the bilge. In looking at the dimensional space to work with being relatively on the small side, would anyone have a good brand / model recommendation that fits this space?
He specified getting a pump that could handle 150 GPH per foot of vessel. That's over 7,000?
Thank you!
Gunni
Mar 16, 2010
5,937
Did this surveyor have certification? Society of Accreditied Marine Surveyors or National Association of Marine Surveyors. Perhaps he got his start with the clipper ships during the gold rush? Is this boat sinking at the dock? You should have a diaphragm pump with remote pickup in your bilge sump along with a pump switch. You should also have a manual diaphragm bilge pump in the cockpit with a pickup in the bilge sump, above the electric pump.
7,752
Alden 50 Sarasota, Florida
Thank you!
That's a pretty big leak!
It your boat is taking on over 100 gpm, you have bigger problems than selecting a bilge pump and appropriate hose size to handle that. Having said that, we have a similar size but it's in my garage as it produces a fire hose size flow rate and pressure which isn't practical on any recreational boat.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Check out Capt Wayne Canning on YouTube. He's got a video on that very subject. Good stuff.
MitchM
Jan 20, 2005
1,031
if you don't have a lot of space in the bilge, fit a bilge pump switch and water inlet tube with screen in the bilge, running up to a remote big - capacity bilge pump like the par jabsco old diaphragm/ belt drive. bilge pump . my par jabsco belt drive bilge pump is located in a dry remote location and is now going on 36 years old (with one pump seals re - build.) i use the Ultra pump switch and have it hooked to a bilge pump counter and high water alarm. (which has never gone off...) I also have a 500 GPH Rule secondary, and a manual whale gusher pump with removable handle, operable from the cockpit.
Mar 20, 2018
7
Thanks for the good ideas. I was thinking the float switch on a 3 way switch at the nav panel would be good.
HAHA... No Gunni, the boat has no leaks (it better not after swapping thru hulls!)
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
What type thru hulls did you use?
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
https://www.boatus.com/magazine/2014/december/bilge-pump-capacity.asp - This is from West Marine (for what it's worth).
I'd suggest TWO electric bilge pumps if you're focused on this. You'll need separate 20 amp breakers and a bunch of battery capacity. (Remember, if you really move thousands of gallons, it is going to a bunch of capacity.) I only have one electric Rule bilge pump in the deep bilge (we have one dedicated smaller one for the forward anchor/sail locker). I think the deep, main bilge is a Rule 2500 (though it may be bigger). It has a three-way switch and uses and electronic switch (not a float).
Does the Hunter you have have two sets of manual bilge pumps too? If the surveyor didn't deal with that, I don't think he was following any ABYC standard for offshore sailboats. (You should have one manual pump inside and one accessible from the cockpit.) I'm not sure the electric one is even required?)
150 gph/hour @ Foot is something I never heard of.
Jun 24, 2014
45
Beneteau 461 Kent Narrows, MD
I think there is some confusion in this email. A pump capacity of 150gal/hour would be useless in an emergency...
I have a similar yacht, a 2000 Beneteau Oceanis 461. Standard installation is an electric pump with a float switch and a capacity of at least 1500 gal/hour better would be 2000 gal/hour. In addition a manual pump in the cockpit with a similar capacity.
If you do any racing especially off shore you are required to carry a 2nd electrical bilge pump.
You can buy a fully automatic 1500g/h pump at West Marine for less then $ 200.00. But installation maybe a bit tricky. The second pump should not be plumped into the same drain hose as the primary one.
Jun 24, 2014
45
A correction to me pervious email. I misread the original email because I have never heard of a pump capacity rating per foot ?! My recommended rating is 2000g/h for the whole boat.
