J W Huhta, Sr.
Just adjusted our oil pressure. It was a snap!Looking from the flywheel end of the engine, under the carb and fuel pump on the right side is a nut encapsulating a flat head adjustment screw. Turn it clockwise one full turn and you get a 6 to 7 psi increase in oil pressure. I did it with the engine not running. Did two turns and got the oil pressure(hot engine) from about 23 psi to about 37 psi.Hope someone can use this info.............Jim
