Are backstays really necessary?
2,288
C30 Event Horizon Port Aransas
Yup, docked next to one for 6 months or so. It had no stays or shrouds at all.
How are thigns going for you Syd? Where has your nomadic lifestyle taken you?
Aug 5, 2006
121
Hunter 33 brisbane
B&R Rig Myths
The B&R (Bergstrom/Ridder) mast support system has been around for a long time (I think the 70's) and the first one's I have seen also used backstays. The systems you see today on later model Hunters do not have backstays and that raises questions as mentioned above. I do not know of any Hunter mast failures that I recall, so I guess it is not problematic for a boat considered to be a coastal cruiser at best or an inland classified vessel......."
We must try and get rid of the Bull S about B&R rigs without backstays on Hunters. What irks me is the throw away line above implying Hunters are only suitable for cruising around in sheltered waters:naughty:.
Hunters with this rig have circumnavigated.
All boats sold or entering European waters must have a CE classification. These classifications range from A to D. A being essentially for unrestricted sailing conditions and all the other categories for various conditions and waters in less than 40 knots of wind and 4 metre waves.
Hunter in common with most other current production yachts above 32 ft are manufactured to CE category A standards. (Catalina/Hunter/Beneteau/Jeanneau/Bavaria etc.) They are no different in this respect to the so called blue water yachts that everyone get excited about. They carry the same sort of gear (and that is what is liable to fail) like Selden masts and spars, furlex reefing, Lewmar/Harken deck gear and winches, Yanmar engines and so forth. Hunters also have lead fin keels and kevlar hull reinforcing. Underwater shapes are all very similar with wide flattish rear sections which beat the pants off old long keelers when reaching or going downwind. They are a lot cheaper because of volume production not lack of seaworthiness. Anyone that says otherwise is a snob, silly old fart or doesn't own a modern boat:)
I might also add in favour of the B&R rig that when my Furlex forestay broke last year the mast stayed up even without a backstay. I doubt any conventional arrangement would do so.
Attached please find a photo of the CE category A plate affixed to my 2004 Hunter 33 rendering it suitable for waves exceeding 4 metres and winds greater the 40 knots. It has had a bit of both with 45 knots and 5 m seas
15,184
Nick:
Just remember it is called Ignorance.
"Ignorance is the state in which one lacks knowledge, is unaware of something or chooses to subjectively ignore information. This should not be confused with being unintelligent, as one's level of intelligence and level of education or general awareness are not the same. The word "Ignorant" is an adjective describing a person in the state of being unaware. The term may be used specifically (e.g. "One can be an expert in math, and totally ignorant of history.") or generally (e.g. "an ignorant person.") -- although the second use is used less as a descriptive and more as an imprecise personal insult."
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Hermit if you look close you will see that by eliminating the backstay Hunter was able to enlarge the roach on the main making a more powerful sail. The jib can now be made smaller with fairleads on inside tracks which help in pointing ability. The shape of the hull has been redesigned by widening the stern and the arch just provides convinience by opening the cockpit and making it larger and more comfortable. I for one I'm very pleased with the performance of the design.
Ross
Jun 15, 2004
14,693
Being ignorant is like being dirty it can be cured. being stupid is like being ugly ,it goes clear to the bone.
Benny
Sep 27, 2008
1,149
Nick, looking at that CE Plate I see that the recommned maximum number of people aboard is 8 plus luggage resulting in some weight limits I could not read. I'm curious about the criteria utilized by the authorities to reach that figure. Here in the US the limit of passangers is left at the discretion of the boat's captain. I have had 15 people aboard for a dockside activity and the waterline hardly went down. Now it would not be practical to sail with 15 persons aboard as well as it would not be practical to take a trip with more than 6. Is that limit of 8 enforced by marine authorities or is it just a guideline?
Hunter 34 Alameda CA
The 500 pound elephant in the room is that the later Hunters have even more pronounced swept back spreaders. That forms a triangulated support structure between the forestay and shrouds like a broadcast TV tower that won't fall down. The backstay was deemed redundant and eliminated. With this type of structure the mast could be made smaller in diameter reducing weight aloft. One drawback would be that the main can't be squared off as much when trying to sail dead down wind. However, reaching downwind with the large roach on the main is faster anyway.
Aug 11, 2006
1,446
Hunter H260 Traverse City
Here's the link that provides a detailed discussion on the advantages and disadvantages of the B & R rig:
Go to: http://sbo.sailboatowners.com/index.php?option=com_content&task=view&id=35&Itemid=87
A recent article in Practical Sailor summarized the advantages of the B & R rig thusly: "We think this concept makes the most sense when used with a mainsail with ample roach and jiffy reefing. With this setup, the compromises when sailing off the wind and the lack of adjustability are offset by a more efficient and powerful sail plan...if you want a no-fuss rig with easy operation, look no further."
Joe
Jun 1, 2004
8,339
I have a backstay adjuster. I think it came with the boat originally.
I am not sure if my mast will bend. It is a uniform cross section from top to bottom as well as deck stepped.
Hermit, on your masthead rigged C30 the the spar is very rigid. It was not designed to experience much bending. Adjusting the backstay tension will affect FORESTAY tension. Therfore, on a masthead rig, the backstay is a headsail trim control.
On a fractional rig, the backstay also connects to the top of the mast, but the forestay connects much lower. This allows the backstay to impart mastbend and affect the mainsail shape. So on fractional rigs the backstay is a mainsail trim control.
You can see many examples of backstay-less rigs besides the B&R. Many racing dinghies, and almost all beach cats do not use them. They are typically rigged with swept back spreaders to form a tripod type of mast support. On beach cats, in particular, the mainsails typcally have a very large roach with 10-12 full size battens with adjusters. Also, the mainsheet tackle is very powerful, 8 to 1 and up. This system, along with a very high purchase cunningham system gives the cat sailor the power to bend the mast without a backstay. In addition, dinghy and cat sailors will have easily operated shroud adjusters giving them the option to pre-bend their mast to match conditions.
The bottom line is this. Your boat was designed with a backstay. It's primary purpose is to control forestay tension. I leave it up to you to find out why forestay tension is important.
2,288
One of the things I have read about my boat is I don't want a larger roach becasue it moves the center of effort back. The article said the C30s that handle the best were one's with the tall rig because it moves the sail plan forward.
If my mast were to bend, the force of the backstay would have to be counter acted by the forward lower shrouds. They don't seem that substantial, but maybe the mast is more flexible than I am giving it credit for. I have heard them called telephone pole masts.
I thought it had more to do with headstay tension.
Aug 5, 2006
121
Hunter 33 brisbane
Fat Folks!
Benny - The figure you could not read is the critical one 1089 Kg or 1.089 Tonnes. This is the maximum load, with full tanks, the boat can take if it is to be CE Cat A rated. The number of passengers is just a guide. If you want to carry a lot of fat people or heavy gear the H33 can have a Cat B plate with the appropriate loading. I forget the actual figure but it is something like 13 people and around 2 Tonnes. Maybe that is the way the Charter Fleets make their money:)
Dec 14, 2009
26
Truant 33 pilothouse Victoria
Often frac rigs have runners that insert at the same point as the top of the headstay. They are used to control headstay sag. Tensioning the backstay on a frac rig pushes the middle of the mast forward and can loosen the headstay.
I find boats with no standing rigging scary to sail on. I always find myself looking for places to hang on. I like standing rigging, all of it. Double lower shrouds, running backs, inner forestay, and all the regular stuff (forestay, backstay, uppers).
Finally, without a backstay where would the HF antenna go?
Salty
Dec 2, 2008
144
Catalina 390 14 Perth Amboy, NJ
To answer the original question, "Are backstays really necessary?" It depends on the design of your rigging. It’s not required for the B&R rig because of the sweep back spreader as mentioned and successfully proven by Hunter, which can be seen all over the world. In my travels around the globe, I've seen many Hunters with B&R rigs and I don't think they flew them there. If the question is about preference, then I'll have to say I've come around to consider the B&R rig after a discussion with a Hunter rep at the Annapolis boat show. His point was the boat was design for most cruiser (most of us don't or cannot bend our mast), and it was a mast head rig, so the mast couldn't be bend using the backstay anyway. He also mentioned the roach advantage as stated earlier. So I think the B&R rig has proven itself over the years to be very reliable.
Ross
Jun 15, 2004
14,693
The simple truth is that to keep a mast up it must be supported in both the x and the y axis. If it were supported only fore and aft it would fall sideways. if it were only supported left and right it would fall forward or back. By setting the shrouds aft of the base of the mast you get fore and aft support and side to side support. A four legged chair can sort of work with three legs but a three legged stool needs all three legs.
DougH
Mar 16, 2009
12
Hunter 23.5 Annapolis
That's the way it was explained to me. A 4 legged chair works fine if its square but a sailboat is normally not square. A 3 legged stool is more stable that a 4 legged rectangle. Its all about the design of your rig.
[FONT=&quot]BTW: I sail a 1993 Hunter 23.5 with no backstay.
Doug H.
[/FONT]
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Not really
I wouldn't call backstays a necessity. IF you don't own a sailboat you certainly don't need them at all. Or a sailboat without a mast don't need them eaither. You really only need one if you have a traditionally rigged boat and intend to sail it, then it is an absolute necessity. One option is to get rid of all you riggin, mast, etc. and get one of these kites they use for kite boarding. Large container ships are starting to research using them as a way to reduce fuel. So like the Mary Poppins song, let's go fly a kite.
2,288
I saw a trawler flying a kite board type kite attached to the deck. They probably used to own a sailboat and then bought a trawler and missed the wind but not enough to go back to a sailboat.
2,288
Now I know why I was thinking the backstay wasn't necessary; It took 2 guys and myself to remove the pin to my forestay. We had two guys hanging on it and one guy working the pin free. The backstay was totally slack. I didn't take the tension off of the main sheet or the topping lift. That is also why when I was sailing, I saw the backstay just hanging around with no tension on it. Even though the topping lift was slack, I had the main tensioned.
My backstay looks old. I was concerned about sailing at all with out replacing it. I am not so concerned anymore. I am going to run a synthetic line as a backup to it though until I can properly replace it.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
It's all design. If your rig was designed to not require a backstay, then you probably don't.
Our 19' boat's fractional rig was designed to not use a backstay, and after 30+ years, the design is proven. I haven't heard of any problems (eg control, dismasting) that is attributable to not having a backstay. We don't find that the rig is unmanageable, or flexes dangerously while broad-reaching or running.
2,288
Well, I guess I should have been more concerned. We left the Corpus Christi marina today to move to Port Aransas. 300 yards out of the marina breakwater. I raise the main, and unfurl the 150 in 20 knot winds. We heel over nicely and start scooting along. Then I notice that the main has a small tear next to the corner of a batton. So I drop the main and intend to sail with only the headsail. With no main to balance out the force on the mast, the backstay breaks. It was one of those closed turnbuckle things. Fortunaltely I had the mainsheet tensioned and the topping lift tight. So we furled up the headsail, and motored straight into the wind for 6.5 hours to get to the other marina at about 3 or 4 knots. It was choppy and rough. Half way there we were able to duck behind some islands that line the channel and the water was much smoother there.
My main sail is old and needs replaced. I am redesigning the backstay to have a spreader so the backstay isn't so close to the helm.
I have to say that the profurl worked better than expected. I was able to furl in that big sail in quite a blow. Also Jeannette handled all the chaos very well, she's a tough old bird.
