Anyway to improve this outboard bracket
Jul 20, 2011
176
1974 Macgregor 22 SoCal - dry storage
Boat will be in a slip, with a Suzuki 2hp, it is not too bad to pull It up after use. But if I upgrade to a 6hp fouur stroke then I'll be more challenging. Anyway to improve the lifting process? Don't want to spend 300 to buy a new one with the handle yet.
You could add a couple of bungies to help with the lifting. Use a block and tackle from the boom when you want a little pulling advantage.
Add springs:
-Will
Likes: Indysailor
That looks like a mount design that has springs to set it in the up position. The small block (pulley) hanging beneath the mount would be used to pull the motor down. A lightweight motor would be normal. You would want a method to hold (lock) the motor in the down position.
JBP-PA
Apr 29, 2022
824
Jeanneau Tonic 23 Erie, PA
If you put a strap around your engine, it gives you a better grip and makes it easier.
pgandw
Oct 14, 2023
253
Stuart (ODay) Mariner 19 Yeopim Creek
I personally would be very leery of putting a 6hp 4 stroke on that bracket. Said motor will weight 60lbs (long shaft), and being single cylinder 4 stroke, generate significant vibrations. In looking through various outboard brackets, the lighter versions carry restrictions on 4 stroke weights, hp, or ban them altogether. The photo of that mount show me a light weight bracket not capable of supporting the motor you propose. Which makes me wonder how much the mount bolts are backed up inside the transom.
Likes: LLoyd B
Jul 20, 2011
176
was looking at some brackets on Amazon and ebay, interesting to see most of them specify they're for 2 stroke or 4 stroke. just wonder why that is, why would it matter whether engine is 2 or 4 stroke as long as long as I dont exceed weight limit?
pgandw
Oct 14, 2023
253
The vibration from a single cylinder 4 stroke firing once every other revolution is not trivial. 2 strokes of 6hp and up tend to be 2 cylinders, both firing twice as often, so vibration is lot less variable. It's the vibration absorption the bracket is capable of as well as the weight.
Fred W
675
Oday 25 Milwaukee
As a rule 4 strokes weigh considerably more than their 2 stroke brethren . We have a 4 stroke ,2 and a half horse Yamaha . Weighs very little .upgrading to a 6 horse the weigh goes from 24 -30 pounds to sixty at least .
I'd look for a used lift . Lot's to be found for $50.00 or less .
I went from a 6 horse ,2 stroke to an 8 horse four stroke . I'm now at 100 pounds !
New lift , new interior support brackets on the inside of the transom .
For your boat , depending on where you saila 4-5 horse might do well for you .
