Well said centerline. I use recycled ground tackle for ours; one that has an eye on one end with a tail of about ten to fifteen feet. As I approach the mooring field, I ready the boat by placing the eye end of the mooring line on the starboard bow cleat, drape the tail under the bow roller an hang the remaining tail over the port side pulpit. I open the boat hook and rest the hook end on the port side pulpit.
Normally I will position the boat directly into the wind as I aim the bow of the boat right at the mooring ball then do a slight shift to starboard followed by a soft burst in reverse as the bow slowly passes by and stops at the ball. At that point I do a dash to the bow, grab the ring with the boat hook and lift the ring up, thread the tail through the ring, release the hook and secure the tail to the port side cleat.
Our boat has a high freeboard, so depending on wind conditions, the above process works about 100% of the time, unless a strong wind (20+ knots) catches the bow and forces it away from the ball. Our boat weighs 35,000 pounds, so if I grab the ball with the hook, I'd best be quick about it, otherwise the hook will stay with the ball as the boat decides to go elsewhere. That I must say is another story, which is why I keep three hooks on board.
