Fuel gauge
I ordered the sender type SSS (I think it was 17 inch for the fuel tank but do check yours) and 2 at 14 inch for the water tanks. I ordered the under ring type FLS-U but couldn't work out how to fit it so I just screwed it down using self tapping screws directly into the polythene. I fitted the cork gasket that comes with it. I fitted the sender about 6 inches back from the front edge. If you fit an access hatch then you could bolt it to the top which would be a better job.The gauges I used were UPFR-BB.I ordered it all from wema direct. Good service.Did you find the photos in the Hunter 34 improvements page?Richard
