I went to the boat today and I found some water in the V-birth storage area. I have two openings below the plywood decking for the bed. Two areas that have water inside not allot but enough to look for the leak. I do not understand the locker cavity. It has two platforms different levels for the ropes and chain. Between the two there is an open area where I assume the water can enter. I thought this water will be dispersed through the two small holes on the front of the bow. Am I thinking correctly on this? Any have any insight on where I should start to look for the leak?ThanksJim
