Same problem on H34
Jim, I'm having the same problem on my '83 Hunter 34. I have found my problem to be a bad sealing of an edge out of reach under the step plate in the anchor locker. I worked for two hours trying to unbolt the plate with the help of a friend. Couldnt reach the back nuts on the bolts. I'm going to cut the bolts off next weekend with a demmell, so I can get the step off. I was able to spot the leak with water hose on and looking thru the inspection port in the found of the V-berth. Good luck with your leak.Steve
