water always seemed to spurt out the exhaust as soon as the engine was started,previous to some starting problems i have encounterd but corrected. My question is how long should it take for water to exit the exhaust. I am afraid to let the engine run for any length of time. Is it possable the thermostat is stuck closed. I removed the front plate from the pump, impeller looks fine and raw water has no problem reaching the pump. Second question can someone explain how the water and exhaust mix and how the plumbing in the back of the engine works in this regard. Thanks...Lenny
