I believe 410 and 420 refrig/freezer systems were the sameQuick Survey;
Do you have a replacement system or original: original in freezer, "new" added in refrig
What manufacturer if replaced and what models of both evap and compressor: both AB
Is your evaporator a box type, a wrap around your entire freezer section or a plate: both wrap around
If it is a box type evap, how does this work for you? does it give you enough room to freeze provisions for most trips?:
If it is a box type does it keep the freezer cold enough to slowly thaw frozen meat? How long does it stay frozen?:
Did you install the replacement or have a pro do it?: pro
Are you happy with it, what changes would you make?: very happy ... both have worked well for 13 years
I am in need of a replacement system and need some advice from other Hunter 410 owners.
Thanks
Probably are if the models are the same year (I don't know this for a fact). But the system on a 1998 410 and 2001 410 aren't the same near as I can tell.I believe 410 and 420 refrig/freezer systems were the same
Since it was pouring rain the other day I finally got back to this question of the spillover fan. Mine was definitely only running when the compressor ran and this was resulting in the temperature getting to 40 or so sometimes.It seems that the spill over fan in my refrigerator only runs when the compressor runs (which runs off the freezer temperature). So the temperature in the refrigerator increase and goes though big swings.
Is this how others 410 spill over fan operates as I would think that the fan should run independent of the compressor.
jsmac;1116690 Anyone have an air only cooled compressor in the Annapolis? Baltimore area and are you happy with that? Anyone run into problems in late July when the temps are 100? Thanks[/QUOTE said:Mine is air only and has been fine up in the Boston area (never had the water cooled unit on my 410). It got pretty hot for a while last year and the freezer stayed frozen (the frig too since back then the spill over fan would run if the freezer). Yes it ran longer with shorter off periods, but worked fine.
It would surprise me to learn that running the unit longer without a water pump would in the end be less total power draw than shorter with the water pump.
