I purchased these "computer" fans through Fry's.com . They're about $6.00 each.
My refrig fan has it's own thermostat separate from the freezer thermostat. I've owned two 410's and they were wired the same.
I also found that pre-loading my freezer with 4 blocks of ice in their own bags all placed in one plastic bag significantly helps keep the refrig colder. The refrig runs less often. I do have to defrost the freezer about once every 8 to 10 days. It takes about 5 to 8 minutes to take out food from the bottom of the refrig putting it in a large plastic bag to keep cool. Empty the freezer into same bag/s. Pouring hot water over the freezer plates taking the frost off. Wiping the freezer and refrig down quickly, then replacing the items. I've got a system and it really saves the compressor use a lot.
At the end of the season, my block ice is virtually the same shape as when initially placed in. They're used as a shelf for the frozen food placed there. Without the ice, freezer runs a lot just to cool the large almost empty space.
Good luck,
Roger
S/V Sailstarr
