Daniel Jonas
We have an early model 356 with the struts going from an area just above and between two fixed ports and the mast. Early on, cracks developed in the fiberglass towards the upper part of the associated chain plate. This problem was taken care of under warrantee. We were told that Hunter either later changed, or made a mistake regarding the appropriate fiberglass material to use in this area. Ours was redone and the fix seemed to be ok.Yesterday, I noticed that there are new cracks below the chain plate. These cracks are horizontal and run between the two ports, but not all the way across. In looking at the new 36 (a 356 with some changes) I note that one substantial change has been made to the way that Hunter anchors this particular mast support.I will be talking with my commisioning crew regarding these issues. In the meantime I would appreciate any feedback that the forum can provide. In particular I would like to know if any of these cracks have appeared in any other 356's and what the resolution has been. I know that the original cracks have shown up for a few of you, because I have seen that discussion before. Thanks for your help.Dan Jonas (S/V Feije II)
