310 Battery Info
76
2005 catalina 310 gig harbor, Wa
Regarding your Battery Setup
This is my battery setup.....
paulj :troll:
Paul, Did you
1. Just rewire the 1-2-B switch so you have AO to switch to House Bank and so you did not have to run any additional wires to batteries.
2. Get a larger capacity Alternator due to increase in your housebank
3.Use an ACR or duocharger between your housebank and your Reserve Batt.
Thanks, Again Paul. Coming down south anytime soon.
Dave in Gig Harbor
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
Truckman
Answer to 1........
No AO switch what ever that is.
I did not rewire the original 1-2-B switch.
The original cable attached to the 1 position on the switch now runs to the new start battery postive.
The original cable attached to the 2 position on the switch runs to the existing house bank battery positive, no change.
The existing house bank is wired positive to positive and negative to negative.
All negative battery cables go to a common negative bar.
I use a one Truecharge 20 to charge both house bank and start battery.
Answer to 2............
No and no comment.
Answer to 3......
No and no comment.
I have a LinkLite battery monitor and the jury is still out on that.
paulj :troll:
Link algorithms, important info: http://c34.org/bbs/index.php/topic,4922.0.html
This recent post on alternator replacement when upgrading a house bank is also pertinent: http://forums.catalina.sailboatowners.com/showthread.php?t=116767
The preferred arrangement is
continue to use the 1-2-B switch
AO direct to house bank
each bank output to 1-2-B switch
C post of switch to distribution panel and starter solenoid
either use an echo charger to charge the reserve bank or use the B position on the switch - simple
Sep 29, 2009
76
Fuse from AO to House Bank
I did some calculations which is always dangerous and came up with a 135 Amp fuse between the AO and the House Banik. Does that sound about right. One of these......http://bluesea.com/productline/overview/13
A surface mount thermal Circuit breaker.
Happy Easter
dave
I refer to this so often, I've just done this to bring it to the top and save scrolling!:doh:
