Manual info under Hunter boat information on the 23.5 . I have a draft for mast raise instructions for review for suggestions. Working on this
If you're referring to the slight bend in your mast crutch that is just above the top support hole on the stern, it's supposed to be that way. The crutch tilts forward slightly when cradling the mast@Kermit this needs a whole lot of cleaning/tidying up, but for better or worse this is how the previous owner helped me take down the mast and stow things.
My mast cradle pole is also a bit bent, but it doesn't seem to create any issues as far as I can see, and the pin went in.
The tarp is just to keep the hatch area dry as we take things out and clean for the winter. I have a 24'x36' tarp for storage but still need to fashion a tent structure to keep snow from accumulating.
Thanks for the clarification. Any suggestions as to how to mitigate the feeling that my boat is going to slide off the rear of the trailer (or the trailer tongue lifting up if not connected to the truck) when I climb up the stern to get in to work on it without strapping it down, or is it OK to strap at that point, just not on the road?I have always told my customers never strap down the foredeck nor the top of the cabin coach. First if the boat should bounce and no give, could and will damage as I have repaired some in the past. Not only the deck but in essence pressur on the hull and sometimes the seal of the water ballast tank lid have given way. Hard to describe but has happened. You need only one strap in the back and when going over the hull twist the strap a time or two to prevent slapping against the hull and damaging it. This is based on experience repairing so the decision is up to you. Also insure that the winch stand has a safety chain attached to it as a secondary should the winch strap ever fail.
Sounds like you don’t have enough weight on the tongue. I don’t recall if the winch stand is move-forwardable but do so if it is. My boat and trailer sorta tip up *juuuuuuust a hair* when I climb the swim ladder. It’s not a concern to me, though.Thanks for the clarification. Any suggestions as to how to mitigate the feeling that my boat is going to slide off the rear of the trailer (or the trailer tongue lifting up if not connected to the truck) when I climb up the stern to get in to work on it without strapping it down, or is it OK to strap at that point, just not on the road?
