I'm fixing up a 2005 Hunter 33, and mostly following Don Casey's book as well as the manual. For the galley, I was able to refinish a lot of the scratched handholds and cupboards by lightly sanding, applying a few coats of teak oil to bring back the color and grain, and then thinning out spar varnish as a sealer. It seems to match pretty well!
First, I made a mistake and wasn't paying attention to the companionway stairs. The treads are real teak, but the sides were badly scratched and I've sanded through to the very light and noticeably white portion of the laminate or composite (what's the correct term here, by the way?).
They don't seem to sell this anywhere, and since it's not real teak, I think I have two options. One is to try to get a wood marker and more or less make it match. The other is to take the stairs to a local carpenter and have him rebuild the sites with some real teak. What's my best route to fix the Hunter 33's fake teak?
Second, the door to the v-birth cabin is fake teak, but no longer fits. Specifically, the frame seems to be about 1/4 to 1/2" off toward the top. I did have an inspection, and the local interior guys at the boatyard look at it. They commented that the frames warp over time, and the best option may be to get it replaced with a real teak door that I could sand down in the appropriate spot to close properly?
Thanks in advance!
Thanks in advance!
