1991 Hunter 35.5 Legend-Head Faucet Replacement
Jul 29, 2019
17
Hunter Marine Legend 35.5 Madeira Beach
Left post in Hunter Forum. No answers so trying here. Any of you know how to pull out shower faucet and replace in this particular Hunter. Sits on small fiberglass ledge that is integral part of starboard shower panel. No access I can see. Maybe remove adjacent fiberglass forward bulkhead in head?? Thank you for your reply
Welcome to the Forum @blaser1234
I do not have a 35.5 Legend and have not seen the shower set up. Maybe someone here has and will provide insight.
One of the things that really works on this sight is to post pictures of the issue. It gives some of us boaters who have been around a few boats an idea of your problem. We can often suggest an alternative action then to get a saber-saw and start cutting up your expensive and pretty boat.
tjar
Aug 8, 2011
166
Hunter Legend 35.5 Tacoma, WA
I do have a 35.5, and I don't know the answer either. I suspect you would have to remove the shower liner panel to get to the back side.
Jul 29, 2019
17
Thank you, but access to faucet mounting and supply lines real issue. Frankly still waiting for Hunter Owner's to reply since unique to this particular boat. Photos really don't help in clarification. Appreciate your reply.
Jul 29, 2019
17
Will look at it again. Can solve with one method but will take a closer look and try to pick path of least destruction to interior. Thank you so much for your reply. Will try and get back to you with
findings.
Two suggestions.
One, I think for about $50 you can call the folks here at SBO and speak for a period of time to a former Hunter Maintenance Specialist. You can PM @Dave Groshong and maybe get a better understanding of the program. I understand the specialist was a supervisor for Hunter manufacturing. Many years experience. That may be a solution to your dilemma.
Second, from the picture provided by @tjar, the panel appears to be two pieces. The upper portion (with the wood holds and shower head) appears to be cover a lower panel. Is that a screw in the lower right corner of the upper panel? If you loosen that can you lift the upper panel out enough to reach up and get access to the bottom of the shower fixture? Additionally the picture shows on the right side a storage area that goes back to the hull. I wonder if there is space behind the shower panel. Can you access that space from the other side of the bulkhead that is to the left of the shower as looking at it in the picture. Since the shower is positioned near the bulkhead there ay be an access point on the other side along the hull.
Good luck
Jul 29, 2019
17
Thank you both for your insights. What is shown in the photo is a horizontal seam. On our boat a piece of teak moulding is located over the same location. It is attached with screws. If there a seam beneath it, then it may come out by cutting out the perimeter panel caulking and prying out. Will try. Appreciation again to you both.
I thought about the caulking. Likely an adhesive maybe silicon.
Why I suggested the possibility of approaching it on the other side of the bulkhead, between the Salon and the head. Upi amy find that the engineer smartly put in a hole to service the shower faucet. Of course the engineer may have been sleeping when someone designed the shower.
Jul 29, 2019
17
Looked at that possibility in the beginning, but between the main panel and other wires using the area as a highway to other areas, simply don't have room to do the deed. Believe that panel in the head was divided to get access to the faucet and supply lines to the shower faucet and other water lines going over to the adjacent basin. Will try. Thanks again for the reply.
Sounds good. I just like to explore all the possibilities when it comes to boat repairs.
I wish you all the best with your challenge.
Catalina 34 Casco Bay
Hunters are still in production.. Why not go to the horses mouth....
Jul 29, 2019
17
Marlowe Hunter has no backup for Hunter Marine produced boats. Have been out of production for some time now and no resources available
JamesG161
Feb 14, 2014
8,078
Hunter 430 Waveland, MS
Most Hunters come with similar shower head faucets.
I have one that the extension hose needs to be replaced, soon.
Not a direct answer to your question, but I intend to repair, rather than replace.
Just like landlubber showers, access behind the wall is tough. Most parts can be replaced.
Jim...
PS: My Hunter full access is a royal pain, but possible to remove the cosmetic "shower stall"
Jul 29, 2019
17
Well, possible if I can get half panel off as hoped. My shower hose is problem as well but since it retracts down into faucet and leak comes up from area around hose probably time to replace entire faucet. Really don't look forward to repeating soon. Shower faucet dates back to 1991-2
Jul 29, 2019
17
Well have a list of repairs to do and prioritizing. Probably will not get to faucet for a few months. Will update, however with results. Thanks.
Aug 14, 2011
182
Hunter 35.5 Legend PCYC Shediac, NB
If I get to mine first I will update and provide pictures for reference
Aug 14, 2011
182
Our boat has been on the hard all winter and the snow has finally melted so getting back at projects. How did you make out getting the facet changed ? I have it on my To-Do List
