We have a 2GM20F on our 1989 Hunter 30. Wot is about 3,300 rpm on our 2 blade prop. We usually get 6 kts at 2600 to 2700 rpm.
I'd never pull the head unless I had first checked the compression and had one or both cylinders low. (Assuming there isn't a valve problem).
Checking and adjusting valve clearances is an easy DIY job.
As for difficulty starting, these enjines are known to take 5 to 10 seconds or even more of cranking with the throttle pretty high to get them to start cold. After the initial start that day, throttle idle and just bump the starter. Away she goes.
Could it be an injector issue?
And I agree you may be over propped. I'll look at my records and tell you what our prop size is.
Ken
Ken
