Running into some issues with my diesel and I was wondering if anyone had any insight. I'll apologize in advance for being a little wordy.
Background: 1990 Hunter 30-2 with the original Yanmar 2GM20F inboard diesel. Somewhat maintained by the previous owners - they tried being DIY people but did not do a very good job of it. Not sure the last time a professional looked at it prior to now but it did not appear to be in bad condition.
I bought the boat at the tail end of 2019 after it was hauled for the winter. Got a good deal on it (bad sign #1), and did not have it surveyed because I'm an idiot.
Prior to spring launch i ran the engine for about 20 minutes in the yard drawing water out of a bucket. Had a little difficulty starting up but I figured it was due to being laid up for seven months. No other issues other than a little black smoke.
Boat was splashed. Huge cloud of black soot on startup, same difficulty starting. Motoring along at slow speed, died after 1/4 mile. Towed to a mooring and had an independent Yanmar tech investigate plus lots of Googling on my part.
Changed primary and secondary filters, did not find evidence of dirt, water, or microbes. Still no luck.
I suspected the exhaust elbow based on other maintenance attempts I had seen around the boat. Bingo, or so I thought. Approximately 75% blocked, which would explain running ok on the stands but dying under load.
Elbow replaced by the tech. I was not there for that part but he reported it seemed to be starting better. I go out today and have the same hard time starting up that I've been having. Tech suggests that I need to blow out the soot and filth still in the engine. Doesn't sound very scientific but ok sure.
I drop the mooring and start cruising around the bay. Nice calm water today. Engine is smoking like a freight train at full throttle. I can get all the way to 3,800 rpm in neutral but with the throttle all the way forward I can only reach 2,600 rpm in gear. Seems to want to settle at 2,200 rpm and finally no smoke. Motored successfully for about 90 minutes and brought it back in to the mooring.
Almost done!
I was making about 5 kts at 2,200 rpm, and was not able to reach the hull speed of 6.8 kts even when pushing it as fast as it would go. Unsure of the size but the boat has a 2 blade prop. I don't think it's overpropped but I'm not sure - at this point I'd dive down there with a yardstick in a heartbeat if it would solve my problems.
The diesel guy is saying the next step might be pulling the head. I trust him but even he admits it's a little perplexing.
Thanks to everyone who read all the way through - any ideas?!
Almost done!
