1987 hunter legend 37
hacham
Mar 31, 2016
3
hunter legend israel
These days I bought 1987 hunter legend 37, without anchor winch and preparation
Is it possible to get recommendations for what is required to add a winch? (Strength, engineering, location, etc.)
W. T. R. winch, I think you are referring to the windlass.... which is basically a winch used to raise an anchor. The "winch" is typically used to tighten a sheet or halyard. The distinction is only important when you go shopping on line and need to enter the correct search term. For "preparation" I'm guessing you are referring to an anchor roller.
For the windlass, you need to decide if you want an electric windlass or a manual? If you go electric then you have another set of issues that include wiring , switches etc. I'd suggest asking a professional yard to do that install if you go that way. If you go to the store associated with this site, and click on "marine parts" and then on "anchor & dock" you will get a lot of choices to search through.
Good luck.
hacham
Mar 31, 2016
3
I want to thank you for your response
Yes you are right, I'm interested in the electric windlass
preparation, I mean the hull structure, strength, withstanding the load, etc, relevant and based on experience to this yacht model.
