1985 Hunter hull
Grumps
Mar 4, 2021
71
Macgregor 25 Trailer
Ok, hope you all know the answer this: I just ran a Hull ID search and what I was thinking was a 1987 Hunter Legend 37 came back as a 1985 hull. Any idea if this can still be a legend 37 or would it be a regular 37? I’m only considering acquiring this boat if it has a solid fiberglass hull and a walk thru transom. (Visual verification is not an option at this time)
-na -NA Anywhere USA
First, what is the hull number which will give you the model boat, month and year when the hull was laid and model year of the boat. Then look under hunter resources for that boat under boat information. The keel is either a wing bulb keel or a fixed keel. What is the hull number which can be found underneath the starboard rub rail on the transom or under the starboard rear rub rail next to transom
Dec 25, 2000
6,071
According to the photo gallery, the 37.5 has a step on transom as does the 37, but much higher. Both have solid FRP hulls below the waterline, and neither were produced in1985. However, the 37-cutter was produced in 1985, a solid FRP hull below the waterline, but did not have a step/walk on transom. You can check out all three models in the "Boat Info" tab to left on this site.
Walk thru transoms with fold down ladders on production sailboats were started by Hunter on August 1, 1986 for the 1987 models if memory serves me correctly.
Likes: Grumps
Grumps
Mar 4, 2021
71
Yeah, I think I may have to go diving to determine if it has a walkthrough transom. Yippee
Grumps
Mar 4, 2021
71
Are you wanting the hull number? It says it’s a 1985, but that’s the issue. From what I’ve found Hunter stopped making the 37 hull at the end of 84 and didn’t start making the Legend 37 until 1986.
Grumps
Mar 4, 2021
71
It is:
HUN36014F585
Any help figuring out the actual model is greatly appreciated.
HUN. HUNTER MARINE
36. Model
014. Actual hull number or hull #14
F. Month hull was laid or May
5. Year hull was laid or 1985
85. Model year or 1985
Hunter would change model year on August 1
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
My 1988 H33.5 had a reverse walk thru transom with fold up ladder. No swim platform; just walk thru transom. I believe a full swim platform was added around 1990.
Grumps
Mar 4, 2021
71
HUN. HUNTER MARINE
36. Model
HUN. HUNTER MARINE
36. Model
Thank you!
Says online that the last year for the 36 was 83
I came on board with Hunter as a trailerable dealer in late 1984-1985 and then with the larger boats. I responded to the hull number you gave me. Call the forum store and ask Mike if he can recall a Hunter with the hull number you gave me. A photo of the hull number would be beneficial
Grumps
Mar 4, 2021
71
Yeah…. That’s a little difficult…. It’s under 18 feet of water currently ‍♂
Although you said visual inspection could not be done at this time, you should have told us the boat was 18 feet under water which is a major issue. The only thing I tried to help you with was how to read a hull number that you posted here.
Since the boat is 39 years old and underwater, I will let others to chime in as to what should be considered.
Grumps
Mar 4, 2021
71
Oh, I am very grateful for you sharing your knowledge. I’ve just experienced several latching onto the underwater part and not help me with my questions. To me, it being underwater is only a deal killer if it’s not a legend 37. The more I’m finding out about this boat it’s leaning heavily to not being one. I severely apologize if I sounded ungrateful.
Grumps
Mar 4, 2021
71
no you are fine. How long has the boat been under water ?fresh water or sat water?
About 1.5 years and fresh water. The legend 37 has a solid hull, so I figure the chance of me being able to revive her are pretty good. If not, could part it out. But, I don’t want a core hull and I do want a walkthrough transom.
@dlochner @jssailem
Your thoughts. Frankly, I would say walk away from this one as to costs, time it’s would take, no insurance carriers would insure this boat, etc.
A sunk boat is a candidate for a land fill. I wouldn't take it unless I was paid a considerable sum and then I'd salvage what is salvageable, sell the lead and aluminum for scrap, and put the rest in a landfill.
Grumps
Mar 4, 2021
71
@dlochner @jssailem
Yeah, I’ve decided to pass on this one. Too many discrepancies for me to spend money to only find out that it’s not the boat I thought it was. Thanks for all your input. I’ll find another project boat at some point.
