1980 H27 Cherubini Rudder Removal
May 21, 2018
1
Hunter 27 Cherubini ST Augustine
I recently acquired a 1980 H27 Cherubini. The rudder was snapped of during the last hurricane. I was wondering if anyone has removed one and would you have any pointers before I start to remove whats left of the rudder post. I am also insearch of one. Any information would be greatly appreciated. Thank you all kindly.
Hunter 27_75-84 Wilmington, NC
Wow, no responses. I have a 1984 h27 and I'm interested in removing my rudder also and looking for help. The biggest problem I see is removing the 4 ss bolts that hold the two halves of the cast aluminum radius wheel to the rudder shaft. I tried to loosen for 2 weeks on last pull out. Tried everything, from several top quality solvents to cutting a groove for a flat head screwdriver and used an impact driver on one end while a helper had a socket wrench on the other. I finally gave up, but the rubber hose that joins the fiberglass hull nipple to the packing gland is 34 years old and at or below waterline, depending on conditions. Would really like to change that hose!!
Jun 5, 2010
1,136
Hunter 25 Burlington NJ
The aluminum Edson quadrant (it's round, not really a quadrant) can get fixed to the SS rudder shaft by (bimetallic) corrosion. In that case it's not coming off without a cold chisel or a Sawzall. And then it's flat-out replacement. I was able to save one on a Superstorm Sandy job; but it meant all new parts from Edson: cable assembly, connecting eyes, everything else. When you do get it off and go to reinstall it, use quality marine lithium grease or even Tef-Gel on it. Don't spare the grease.
If you have the shaft assembly out, be very circumspect about inspecting the condition of the stainless. Any sealed-up internal stainless pieces get horribly pitted-- even so small you can't see it-- and the next step, unlike with aluminum or even plain steel, will be snap! --sudden and catastrophic failure. I hate to spend your money; but your boat's nearly 40 years old and you're probably looking at an all-new rudder assembly including the shaft.
I would not waste time in boat junkyards as the rudder you think is serviceable will be as old as the one you have now with the same potential problems. If you're adamant about saving as much as you can of what you've got, consider grinding some of the bad stainless and welding in new bits. You'll want a pro for that. The fiberglass is easily mended-- you can get it to close enough of the original shape and then fill and fair as much as you have to for it to be better. It's not vitally mission critical; it just has to turn the boat. But use quality marine-grade materials. Typically the blade of the metal structure gets 'glassed to one side; then the other side is 'glassed to that and the edges well lapped with fiberglass tape. It's not that difficult if you have even a basic knowledge of fiberglass repair. If I were there I could do this in my sleep.
Don't bother with replacing the foam. It's worthless-- adds nothing but weight, holds water and mold, fools you into thinking there's some 'strength' there, but there isn't. If your stainless steel is rotting, no doubt it's due to the foam holding water against it. At Cherubini we evaluated this and determined that fitting a little bronze drain plug into the bottom (not the fitting, just screwing the plug into a hole) is a better decision than replacing the foam. So long as you've got ample skin thickness where the blade is 'glassed to the shell, it'll be good enough.
As for the Edson parts, call Edson directly and talk with Will Keene. Tell him I sent you. :waycool:
Likes: Fred Villiard
Apr 22, 2011
974
Hunter 27 Pecan Grove, Oriental, NC
Like amcmahon said, your toughest obstacle will be removing the aluminium quadrant that grips the ss rudder post. I removed mine last month in order to access the rudder packing gland. I was at a diy yard, but finally resorted to getting professional help to remove the 5 ss bolts (mine had one bolt that went part way into the rudder post along with 4 that compress the quadrant halves to the post). The technician used an impact wrench, various fluids, and a lot more muscle than I have to dislodge the bolts. Once you have the quadrant off, there is one more bolt that is located at the top of the rudder assemble in the cockpit. Release that one and the rudder should drop.
