I am looking for recommendations to prevent freshly cut/drilled/grinded 316 stainless steel from future surface rusting/staining.
In this particular case, five years ago I removed my teak hand rails and instead replaced with the stainless steel arrangement in the below picture. Over the years, the hack-saw cut ends of the tubing inside the fittings developed the typical SS surface rust. Also I had to grind the bottoms of the fittings from flat to slightly concave to better conform to the curve of the cabin top surface. This removed the original factory finish so the exposed SS also surface-rusted which bled a bit into the surrounding painted gelcoat.
The rust has only had cosmetic effect ... no deep corrosion at all. But now I know that it does happen, I would like to avoid a repeat in the future. So far, I have applied to the exposed cut/ground surfaces SpotlessStainless citric acid based stainless steel cleaner to remove the rust and passivate. (By the product's description citric acid does passivate and I have had excellent results with it on many exterior stainless steel components.)
I am also thinking to apply a thin coat of West Systems' epoxy to both the cut tube ends and to the ground fitting bottoms before I reinstall.
Aside from sending the pieces to a professional for industrial polishing and passivation, any other DIY suggestions?
