If the whole trailer is floating and the back bunk and front bunk are both in contact with the bottom of the boat then I don't see why it won't stay there when out of the water. If only the front bunk is touching then when it comes out it is on the front bunk and as it rotates about that bunk down onto the back bunk the bow rotates back away from the V.I don't think the steepness of the ramp has any bearing on how far back your boat settles.Since adding a second axle,with four tires my aluminum M trailer now floats like a raft, so regardless of ramp angle my trailer is always at surface level and stays hugging the hull while loading.And it still ends up 4 inches back from the bow block just like it did when trailer wheels were in contact with ramp.
For most of us that have sinking trailers when you pull the boat to the V in the water take a marker and mark where the V is on the bow. Then once in the parking lot and after the 'bump' see where that mark is now. It won't be at the V,
Sum
[FONT=Arial, sans-serif]============================[/FONT]
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links
