I was out racing tonight and got some pictures of my mast. It is bent toward port and seems to be raked way back above the spreaders. The gent I was sailing with thinks I should shy way from bending it between trees as I was planning. (Using the trees as anchors to gently pull against the bend with a come along.)
He thinks I should just use the shrouds. (I think they will pull through the deck!) Right now the upper on Port is tight. lower Port is loose.
Upper Starboard is loose and lower Starboard is tight.
There are no kinks or noticeable marks in the mast. There is a mark on the mast cap! I think someone backed into something with the mast while it was laying on the boat.
Any help is greatly appreciated.
Edit.. Back stay is very loose.
