gray painted Yanmar engine?
101
2006 Hunter 33 Santa Barbara
I have a Yanmar 3YM30 engine in my 5 yr old Hunter 33.
I didn't really pay attention when it was new, but I now realize that the engine was painted a gray color. I notice it now because the paint is flaking off the flexible parts - the rubber tubing etc. It's actually creating quite a mess. Is this normal? I'm wondering if the engine was actually an older one (a used one) that had been prettied up to appear new. I'm thinking this in part because the serial number appears to make it quite old (E04448) for a boat that is only 5 years old. Any help or suggestions would be welcome.
Jan 4, 2006
7,436
That's Exactly What Happens .....................
................... pretty well for the life of the engine. My 2GM20F is now thirteen years old and the grey paint is STILL flaking off the hoses and other flexible parts. Makes a bit of a mess but I just vacuum it up at every spring cleaning.
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
The 3YM series is one of Yanmar's newer designs - that's probably why you have a low SN.
May 17, 2010
99
hunter 33 marina del rey
Many shades of gray
I have a 2005 Hunter 33, It was also painted gray. there is some flaking of the paint from the flexible tubing, but not much. I'm not down at the marina so I can't give you a serial #.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Normal
Like already mentioned the #YM is the newer model Yanmar and no way you got a older used engine.
Nick
Nov 6, 2006
10,150
Sounds normal, Syoun. The serial number is lower than ya might expect because that is a European assembled engine. The only problem with that here in the US is that some ancilliary parts are slightly different.. I don't remember which ones, but ya have to make it a point to tell any service or parts guys that it is an "E" engine.
ENJOY.. My 27 year old gray Yanmar sometimes still flakes paint off the hoses ..
May 28, 2009
764
Hunter 376 Pensacola, FL
They painted the engine AFTER they assembled it? As in hoses and everything? Belts too?
Ours was way too old when we bought it, it was on at least its second, maybe third set of hoses and belts, so there's no paint on them.
Sep 20, 2006
2,952
Perfectly normal, but a PITA. I too get flakes constantly in the oil drip pan. My 05 3YM30 is around that same serial no., so is nothing unusual either.
BTW, did you get your overheating problem solved?
89
Hunter 31 Portage De Sioux, MO
Must not be making paint like the used to. My Yanmar is from 1985 and the paint is still where it should be. Everything is still pointed grey. We have owned the boat for 7 years and I have never seen a chip of paint anywhere. :D
Jan 28, 2012
101
Responding to Scott about overheating problem -- NO.
More details on that thread.
Thanks for all your responses here - very useful (at least I know the paint is normal). I had suspected it because of the overheating problem & whether it was a symptom of my being taken for a ride!
best
steve
