This wiring project has turned out to be a lot more work than anticipated. Despite what Maine Sail says a 1/0 cable is tough to work with. All I can think is that he and others with large battery cable have much bigger boats. Or at least a lot better access. The first picture is the starter post where I am trying to connect the new 1/0 cable. The lugs are thick and leave very few threads on the posts. The cable doesn't twist easily so getting several lugs on, four in this case, where you can't even get a hand is no fun. Gave up on this part at end of day.
Did manage to get down into the locker and wire the panel. It is shown without the covers over the fuse and new 12v bus. I forgot to buy the 1/0 cable from the charger fuse to the bus.
Also mounted the fuse in the bilge where the two new 6v batteries will live.
Then I was able to use a drum sander on the drill to enlarge the original battery switch hole. The new Blue Sea switch then inserts from the back.
Anybody need fifty feet of #4 cable, lots of pieces, both red and black.
