Looking for the largest trailerable sailboat
678
CM 32 USA
I am being badgered, not badgering anyone. I am still looking at the hundreds of sailboat makers out there. CM is one I am interested in.
I had a VW as a kid that had a rust issue. I do not go around saying all VW's are rusty. If I did, it would show my ignorance, not a problem with VW's.
The hundreds of CM sailboats still in use today says they are well made light trailer-able sailboats, which is why this is on my list of possibilities. I am also looking at Hunters, Cats, and many others.
What I do like about the CM30 is the sail-drive and the space it is provided inside the boat. That looks to me to be a smart idea that is well thought out, if maintained properly. I am not a fan of the look of a kicker motor hanging off the stern of my boat for several reasons. I am also not a fan of a built in engine that takes up space, gives off fumes, and is hard to maintain because it is built into the boat. The sail-drive is what most interests me in the CM30.
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
buy it already!
Why don't you just buy it then and not ask for anymore advise? :confused:
KD3PC
1,069
boatless rainbow Callao, VA
What I do like about the CM30 is the sail-drive and the space it is provided inside the boat. That looks to me to be a smart idea that is well thought out, if maintained properly..... I am also not a fan of a built in engine that takes up space, gives off fumes, and is hard to maintain because it is built into the boat. The sail-drive is what most interests me in the CM30.
The sail drives of that era are most often dissolved or dissolving rapidly. Few were maintained properly and even more still had that nasty engine attached to drive it.
No way to do without fumes, maintenance and repair with an ICE...
The gasketed hole in which it mounts often leaks in to the roving, so have a surveyor with saildrive experience check it out, as a new drive can easily be tens of $1,000 to replace, plus haul charges.
Oct 2, 2006
1,517
Jboat J24 commack
I had one of each and even with both boats boats needing NOTHING the 29' cost 10 times as much money to do anything DIY or otherwise
gallons of paint
feet of running rigging
feet and size of standing rigging
feet of electric wire
Something as simple as moving the masts off the boats for winter storage goes from a simple one person job to three men and a small boy
taichi
Feb 21, 2010
57
Hunter Hunter 23 Oshkosh Wisconsin
Amen to you Scott T-Bird - I think you pegged it: "If you are dead-set on getting the boat you describe, then by all means go get it and stop with the pretense of asking for advise. taichi offered a very thouhtful and unobjectionable review of his experience with a boat that he owned. It sounds like you object to his comments because you are really just looking for reassurance regarding something that you already decided upon."
I took a minute to check out the Clipper Owners website - they didn't have that back when I owned mine - looks like there are about 12 CM32's still alive and about 26 CM 30's - I am sure that one of there owners willl be more than happy to help you part with your money.
Is it really badmouthing when your telling it like it is? If it was such a quality boat then why were they in and out of business so quick? If you like Bill Crealocks designs so much then I would encourage you to find an old Pacific Seacraft or Columbia (there all old), but solid classic well healed and respected boats that are worth keeping up. You would be proud to own one of those.
You came to the forum asking for advice - there it is.
Oct 6, 2011
678
CM 32 USA
I came here looking for like minded people that love the water and the wind. Most people here fit that bill, however several of you are in need of moderation. your tact (if you have any) is lacking and you are rude.
Thank you for the kind replies from the helpful members and thank you that I can ignore trolls and flamers on the internet.
Oct 24, 2011
258
Lancer 28 Grand Lake
I think everyone is giving you honest advice. But of course, they are not 6' 4 and 300 pounds. I am 5'8" and 140 pounds, and have a lancer 28, my wife is the same height as me, but a little heavier, but we both find the boat roomie enough for us. I got mine in exchange for a porsche 944s, i couldnt find a buyer for, i valued the car at about 5k, I got a boat worth about 3k, but i am happy, because with a lot of hours, and a little bit of expense, i can have a really good boat on the water, by this april. I am the type that works on a boat all the time, so in a few years, it will be an excellent boat. I will do everything, re glass, re wire, re design, I have already stripped all the bad paint jobs done on it, and took it back to the gel coat, i am also half way through re wiring, and have taken the toe rails off, and glassed the hull deck joint.
The boat is small (my last was a 35 footer, but it suits us, we are used to camping, and we have more room, and more luxury on this boat, than in a tent. I doubt though, a man your size, would find a comfy bunk in it, or be able to comfortably use the head, but it is one of the but it is one of the biggest fixed keel trailerable boats, whcih is what i wanted. I had a 26 foot grampian with a large beam and big draught, and it was not trailerable, and when i went to look at a 24 footer after that, i just couldnt believe that 2 ft made such a big difference. When i had the 35 footer, their seemed to be plent of room, now at 28 foot, its cramped, but we have full standing head room (in most of the cabin) very little storage space, enough bunks to invite friends. Its a nice boat, i saw them go as cheap as 2500 on a trailer, and the trailer must be worth 1500, But what you really need to do is pick the boat that is suitable to you. Then use these forums, to get advice on how to re build it, repair it, or modify it, to your needs. Like i say, i am 5'8" 140 wife is a bit heavier, what we look for, is completely different from what you look for. We want headroom, 5 foot nine and up, six foot berths, room for friends, room for our gear (we didnt really get room for our gear with lancer but cant have everything) ease of launching, ease of rigging, ease of handeling, cheap boat, cheap to repair, so far we have got what we wanted. Would love more storage space, but on a 28 trailer sailor, that aint going to happen.
Make a check list, and go with what suits you.
taichi
Feb 21, 2010
57
Very sorry that you are taking my responses as rude or tactless, but there is no way I can advocate for encouraging someone to buy a 40 year old boat that was lightly buil to begin with just becasue it could potentially be trailered. I grew up on the shore of Lake Michigan and have been messing around with many boats for 35 years, your getting good advice from myself and many others on this forum - sorry that the truth hurts, but the reality of the boat that you have apparently fallen in love with is that owning one and keeping it afloat would not be quite as pretty as it looks from the old brochures from 1972 that your looking at.
Anything more and I am wasting my time, out.
Nov 8, 2010
11,386
GM,
I'm pretty sure that people here are not badgering you. With respect, it sounds like you have made up your mind and you just don't want to hear what they are saying about that choice.
If I look back at the start of this thread, there were at least three boats recommended that would fit your bill based on what you have told us; the Luger 30, the C&C Mega 30, and maybe the o'day 272. You didn't even MENTION any of these comments before diving into the CM 30.
Old boats are like old houses, if you buy one, make sure it has GOOD BONES. Frankly I would never buy a Clipper, because you would get maybe 10 cents back on every dollar you invested in it. You would spend $10K to make a $8K boat a $9K boat. Really. Start with something quality. If you could buy a freeking C&C for $7K, why would you go anywhere near a clipper?
But hey, boats are emotional, irrational purchases. Why should yours be anything different? And you may have requirements that we don't fully understand. Good luck to whatever you choose.. We all do love the wind and the water.
Oct 6, 2011
678
CM 32 USA
The three boats you mentioned, do they have a sail drive kicker? Do they often come with trailer for under five grand? I am not dead set on any brand but I do have a set of things I am looking for. If I get a boat with an exposed engine I want one that is built in and not added on like an afterthought. Example would be a Mac 25 and Mac 26's. The 26's have a place for the engine and a place for the fuel.
In the last day or so, I have decided I may well want the two masted CM32 with the aft berth. That will cost more and be much harder to locate one. In the spring the marina will again have sailboats on trailers parked in the grass for sale. Big hunters, odays, ericksons, and about anything. I may well work out a deal on one of them, we will see.
I am sorry some here chose to focus on me and not the subject at hand, sailboats. If I did or said something to cause this I am sorry.
Still interested in positive advice, which 99% of the posts were. Thanks for your help and your kind words. My wife and I are both approaching retirement years (55) and our health is not perfect. I am hoping to get in a couple years of sailing in the fresh air and sunlight while we can still enjoy it. I do already have two boats. A 19 foot ski / power boat with a 150 HP engine, and a MacGregor 25. Both boats are in great shape, and need nothing. I purchased a slip for next season, and I am hoping to find something larger than my two boats for life on the lake next summer. If I do not, I am still in good shape as the Mac 25 will get us into the great outdoors just fine.
Thanks again everyone for your ideas, and I am researching each and every boat that is being suggested. The Hobie 33 sounded good, but I believe them to be over my budget mark.
GM,
caguy
Sep 22, 2006
4,004
I bought my luger 30 for $1000, trailer included. Better van a kicker it has a well that the outboard drops down into. It has 3300 pounds of ballast and a swing keel. It has a built in mast raising system that only requires 1 person.
678
CM 32 USA
Looked that up on Google, and I would be quite happy with that boat as my first large sailboat.
I am realizing the boats for sale in the marina grass on trailers are the hard ones to step the mast, and tow down the road. A boat like I am looking for is in backyards all across America, and not out where they are easily seen.
Thanks for the suggestion.
Nov 8, 2010
11,386
I know you currently have a Mac25, but have you thought about a different boat in the 26 foot range? Above this size (the 30 footers), you have to make major compromises in the boats sail-ability to make it trailerable. It might be 30 feet long, but it has to deal with:
Beam: Limited to 8 to nine feet
Weight: Practical limits at 6500 lbs
Mast height: Deck stepping keeps masts in the 30 foot range
Draft: Needs shoal draft to trailer launch
These limits in most combinations make for boats that are ugly, awkward, slow, or dangerous.
Our little First 260 has an inboard diesel and a wormgear lowered swing keel. It rides on a dual axle trailer and could be ramp launched in a pinch. She also pretty (IMHO), faster and more seaworthy than 95% of boats her size. I really think its a great length.
My simple point: Going for BIGGEST is not always the wisest. Maybe think about you do not like about the Mac25, and see if other boat in the length meet your needs?
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
Or...maybe another way to look at this, in the slip for 9 mo?, well, why not 12? If size is important then how important is the need to trailer it?
May 24, 2004
7,230
CC 30 South Florida
You want life on the lake, already own a powerboat, a sailboat and have a dock. How about a houseboat?
Oct 6, 2011
678
CM 32 USA
My only concern about being able to trailer it, is going after the boat and bringing it home. I have found several 35' project boats darn near free, but how do you move em? About can't. Cost prohibitive to move.
I have winters here, so all boats out of the water about three months of the year is another reason I need a trailer-able sailboat.
Oct 6, 2011
678
CM 32 USA
Looking good.
I just lost a trailer and a yellow ladder just like that one. ERRRRR
Ross
Jun 15, 2004
14,693
I had my Islander 30 moved twenty miles for 500 dollars.
Oct 6, 2011
678
CM 32 USA
What would the beam measure on a Prairie 32 -027? I found something that suggested it is 8 1/2 feet? That does not sound right.
