On my Catalina 310, with Universal m25xpb, I get a lot of chatter from the prop at low rpm speeds (below 1500-1800 rpm) . sort of a clanking from the prop. If I run the speed up to above 2000 rpm or higher, is very quiet and very smooth...It also is very smooth in neutral gear. Is this the normal noise from a Catalina 310 prop at low rpm or could it be something more critical that i should be looking at.
Thanks for any pointers...Bob
