The earlier Pearsons were solid glass, but the 33-2, 34-2, 36-2 made in 1989 and after are cored below the waterline and solid glass above. The deck is also balsa cored. If you look below the v-berth, you can see the balsa core with a flashlight. Also, in your lazarette, you can see where the coring ends and the solid glass begins. When I installed my depth and speed instruments initially, I had to dig out the core and fill with thickened epoxy. This is not widely discussed in Pearson's sales literature and many boat brokers have represented these as solid glass when they are not. Good luck and good sailing, Ron
Ron,
Good info! And all that more confusing.
I was actually on-board a friends 33-2 last night and found no signs of core and even sapped a few shots and looked in the locations you indicated. I have a guy interested in one and this one may be for sale so I was there for other reasons but did get to poke around quite a bit.
My friend installed an Airmar transducer forward of the keel and found solid glass in a freshly drilled hole. This I would not suspect odd even in a cored boat as usually the center-lines are solid glass. My guess is that they either hid the core very well or some of these may have been built core-less hence the confusion? I can't imagine they built cored and core-less models of the same hull as a production builder. Morris does that, they'll do what ever an owner orders, but I doubt, as you do, that Pearson would have.
I found no core transitions/humps that are indicative of a core sandwich nor any visible core through the greenish/semi-translucent fiberglass below water.
I forgot to ask what year his boat was but I recall it being a 1990? I have also seen a 1990 P-31, same vintage hull design, that nearly tore the keel off and there was no core in that boat either, at lest within a foot or two of the keel, but perhaps they started in the 33-2 and the 31 was solid?
If you could post that literature it would be much appreciated.
