Burners and Happiness
Thank you Steve. If you inadvertently turn the Origo off, can you relight it immediately? Are the tops of the Origo stoves built as strongly as the tops of the Force Ten stoves? Do they come with or can you get pot holders?
That's a good reply.
My SS Origo galley range is built about as strong as the old standard of the industry, the Force 10.
The metal might be a skosh thinner, but it's a strong construction.
Of course you can re-light the Origo burner immediately. IIRC the pot holders (adjustable clamps) are an option. We have them; they are a simple and robust design.
Reread the immediate three replies on using an Origo.
It is not complicated. There is no problem of flameups like you might get with a pressurized alcohol or kerosine cooker. To repeat: the Origo does NOT have its fuel under pressure.
Note B: a "BTU" is a measurement of heat output for these burners, no matter what the fuel used. No matter how you create the heat energy, the output level of the burner will determine how long it takes to boil water or burn a steak.
Note C:
All stoves, no matter what they do to make heat, have plusses and minuses.
Sidebar: I have used a propane cooker for many years before we bought a bigger boat with the Orgio. I like either one just fine. Heck, I once even used a Primus kerosine cooker for a while.
Quit worrying about what fuel your neighbor is using for heating coffee or baking cinnamon rolls and just sit down enjoy your coffee and a fresh roll! If he/she is happy cooking it and you're happy eating the chow, that should be enough.
LB
