Well Centerboard project to begin. As mentioned in various posts I have a very loose centerboard. Meaning it sways side to side considerably. After putting the boat in a easier to work with Trailer for full keels I am now able to work on the centerboard without worry.
Here are some pictures. You can see some chunks are missing from the board and the pendant is just knotted on. Yikes.
From what I can tell right now, I need to do the following:
1) Remove the centerboard by removing the plates and wedges.
2) Repair the missing chunks of centerboard (with fiberglass?) prep and paint the centerboard with SSB bottom paint.
3) Clean up the centerboard housing and paint with SSB bottom paint.
4) Replace the pendant.
5) Put back the pin and wedges (with 3M 4200 or 5200?) and the plates to hold it all in.
Anything I may be missing? I'd like some insight to repairing the missing centerboard chunks. And until I get the centerboard out I can't tell how bad the pin and wedges are.
I got a new pin and wedges ordered from Rudy coming as well as a pendant.
UPDATE: 11/10 -
You can see the front of the centerboard and trunk here. Note how there is more of a gap on the Port side vs. the Starboard. Also the screw that holds the Port side wedge was missing. A big piece of gelcoat is missing in the front of the centerboard probably from getting hit. More to come on that below.
Using a impact screwdriver from local autoparts that normally I use for removing brake rotors made the job easy. Screws came off very easy with a few light whacks with a hammer. One thing to note is that I had a little water come out when I removed the two rear bolts from the plates.
The wedges came out very easy with a 1" putty knife. The Port side came off easy since it didn't have the screw securing it. This allowed the wedge to separate a bit, more on top of the wedge than on the bottom of it. Also had less caulking holding it then the Starboard side.
When I removed the centerboard I found a likely culprit that most likely didn't allow me to raise the centerboard all the way up. Its a large lure with tremble hooks at the end
Here is the view of the parts taken off from the centerboard and trunk. For reference I plan on going to Home Depot or Lowes and match up the screw sizing. This will help me document for any issues down the road.
Over all the pin and wedges were not in very bad shape but I did figure out why I had the side to side play. First the pin is about 1/8" smaller diameter than the centerboard hole. Second the Port side of the pin was worn down a bit. Third the gap between the centerboard and the wedges. This translated into the overall side to side play I had with the board in general.
Here is the starboard side of the centerboard with the pin showing the gap in play from the pin wear. Rudy from D & R Marine indicated that these pins are made from DuPont™ Delrin® acetal resin.
Here is the Port side where the pin was more worn at the edge adding more play.
This picture below shows the 1/8 inch play I had with the Centerboard hole and pin.
Centerboard removed showing the Trunk without the plates, wedges. Looks like some serious cleaning needs to take place here.
Ok so I take a look at the stern end of the trunk. WHOA?!? The rope was not wrapped around the pulley. Hmm wonder why it took some strength to get the board up.
Overall view of the centerboard off the boat. Good shape except for some dings and bangs here and there. As bad as it looks I can't believe its even this good shape after 25 years.
Stay tuned.. for more...
UPDATE: 11/10 -
