Hello all you 310 owners out there.
I am looking for a little help finding out where I have Saltwater coming into my bilge. It has been driving my nuts for some time now.
Here are a few clues to help.
#1 I have a dripless seal shaft that does not drip a drop under way or not
#2 Over the last two weeks idle at the dock the boat bilges were bone dry
#3 No water leaks from anywhere on the engine or raw water strainer
#4 No leaks from raw water through hull or through hulls for galley and head sink drains, or intakes for head and as well as holding tank sea cock under way I only have the engine water seacock open all others are closed.
#5 After a 1 hour cruise motoring only in calm waters the bilges are now full with salty water.
#6 Directly under the primary filter in the aft bilge there is a small accumultation of water less than a 1/2 cup in the corner
#7 There is no water coming in from around my rudder post and shaft alley is bone dry.
The aft shallow bilge forward of the engine fills up first then fills the forward bilges one after the other. So I know its not coming from keel joint.
Any help will be greatly apprciated.
Dave
Dave
