Witzend, I have attached a photo which shows where the leak is. The upper and mid bearings are attached by 4 bolts. Water is not coming in between them where you would expect the packing to leak, but from the joint under the midbearing where it sits on the fiberglass reinforcement for the rudderpost. Also attached is the 310 spec which should be in your manual. Happy New Year thanks Paulj for the Photos from your previous Posts.
dave
dave
Where is the mid bearing and why would the bearing provide a seal and not the packing. I posted the only drawing I have right now, which is the C34. The 310 is probably similar. Please mark on the drawing where your leak problem was if you have the means and re-post. Thanks,
