Any owners out there ever managed to remove the first safety rail stanchion forward of the pushpit stanchion ? I`m getting leaks into the heads and kitchen wall lockers on both sides visible directly underneath this stanchion. These leaks were once just an irritation but the level of leak from this winter`s rain is now causing a real problem ( even though the stanchions were actually covered with a boom tarpaulin from November to March)
The internal glassfibre roof cladding totally prohibits even finger access so I`m left conteplating cutting sections of this sturcture away to allow a socket tool into the nuts.
Seems a bit drastic but I can`t see any other way.
I was also wondering that although the water might be entering from where the bolts come through the outer hull maybe the water is getting through the hull from a different place and then only becoming visible at this point ?
Any ideas --------- or better still ----------- any successful solutions ?
