Jees... how accurate does this need to be? It has been running for over 500 hours way the hell out, and yes it wore the bearing, but still did not have any play in it. The output bearing in the transmission has no play in it as well and is not leaking. So I don't understand how on the one hand you need a laser to line it up and then on the other hand it has been running with significant alignment problems for 9 years without any significant damage? Remember the engine has movement for alignment correction, so I would think it just needs to be in the range of the scope of the engine mounts while keeping it generally within the center of the shaft tube.
The real question in my mind is will the braze fail? It would seem that there is not much side force being applied here and if the cut is made at the bearing flange, the leverage being applied to the joint would be much less compared to cutting it further up the strut. The brazing could flare out on the bearing housing as well. When the cut is made it can be ground so when the parts contact it will be in forward/aft alignment, and holes drilled for 2 brass alignment pins so it would have no sideways movement when brazed. I need more inforfation about brazing before I will rule this option out.
Digging it out dosen't really scare me, glassing it in again does. How does one keep the resin from running down the strut? Is this done in the factory upside down? Seem like a very messy problem and difficult to keep void pockets from forming. There is a large volume here to glass back in.
Roger, just saying "Don't think about it" without substantiating your comment holds no weight with me. I get the impression you are a very knowledgeable and competent sailor, but please explain? BTW, I have contacted a Thordon distributor and they are looking at providing me a blank bearing. Not sure how I can re-cut the flutes for proper water intrusion needed for lubrication after it has been re-milled, maybe just by hand?
I appreciate all your comments!! This forum is great for gathering others views and experiences and although I may not always follow everyone's advice I do value it.
I generally think outside the box and want to consider all the possible options as carefully as I can.
