Ground paths and AC grounding
Even with a Drivesaver, that decouples the shaft, the raw water cooling system still creates as second path to ground other than the grounding plate.
Hmm, I don't understand how that could happen with hoses between the HX and the muffler.
1. Calder's book also favors a separate ground "Buss", with a ground wire to the engine. This, as opposed to running all ground wires to use the ENGINE as a ground buss.
2. ... but I'll go with assuming that those book writers know more about it than I do ... but this thread makes me want to look closer for one. If it's not there, i will not add it.
1. The diagrams in the Casey book references from Scott and MS make it very clear why a ground bus is preferred --- electrically. In addition to the electrical issue with varying "potentials" that certainly would be the case with a bunch of different wires even if they all were connected to the same position on the engine, it is also a simpler wiring technique. It's simply a heck of a lot easier to install a ground bus bar, or a Power Post, and then run one single wire from it to the engine, because you can add more grounds to the bus bar in the future much more easily than you can to an engine bolt .
2. Ron, as I recall, Calder's discussion gives pros and cons for doing so with a very good diagram showing how two boats' grounding (AC & DC) can serve to set up stray current corrosion. I think he concludes it is good to connect them, but the text doesn't make it an absolute. Again, I don't have the book here with me, but remember going through this same thought process years ago, and deciding that for me, for my boat, the excellent wiring in our marina, and because of our boat's use (rarely, if ever, plugged in) that I did not pursue it any further. I will re-read it all when I get home. I know -- sometimes I could be plugged in at a strange marina. I think we've all been to pretty strange marinas in our times!
Or my marina's wiring could go belly up. For those with inverters on board that are used, remember, you don't have to be plugged in to need to deal with this issue. Or a lot of other bad electrical things could happen. Good point, thanks for bringing it up in that way.
BTW, Calder's is the best I've seen in discussing the WHY, as compared to just saying you should or shouldn't do something. That's why I like his book so much better than some other reference sources. I know it's a heavy read for some, but I've been forced to plow through engineering textbooks for altogether too many years, and now that I can do so voluntarily, WOW, it's fun!
