Re: Fixed vs. Free Wheeling Prop - Coming Soon !
Once again!! OUTSTANDING, Main.. after considering this carefully over a nice Merlot, the only thing I see is that the force on the scale will be less than the true drag force on the prop. It will be reduced by approximately the cosine of the angle between the string and the “strut”.. assuming that the strut is kept nearly perpendicular to the horizontal part of the test rig and the hinge has minimal bend. From the pictures, I measure about 40 degrees so the scale reading should be multiplied by 1/cosine. If the angle is 40, and the scale reading is 10 pounds, then the (approximately) real drag on the prop is :
10 X 1/cos40 = 13.05# Since this is true, the difference between spinning and locked will be bigger than measured too.. (Injecting my bias now) when you measure 20 # with the prop locked and 10# with it spinning, the actual drag difference will be 13and some change and not 10.. So when it looks better to freewheel, it will be LOTS better. (except maybe in Canada)
