Was it wire to rope? I cant imagine handling bare wire with your hands
No, it is all wire. But you use a messenger line on the “car” that travels up and down the foil groove. When the sail is hoisted in the spring, you connect the head of the sail to the wire. Then, I pull down the messenger line , which brings the “car” down the opposite groove as the sail. Once the sail is fully raised, the “car“ is low on the foil and gets pinned in place. Remove the messenger line for the season. The tack is tightened with a pendant line, and you are ready to sail.
in the fall, I tie a messenger line to the “car”, remove the tack pendant, and pull the pin holding the car in place….the car travels up the grove in the foil as the sail and other end of the wire slide down the opposite groove. The messenger line stays in Place over the winter to then pull the sail up again the next season.
It’s not that hard, but the whole system is different than a typical furler.
I am anxious to try out my new Harkin Furler next year once I get the mast stepped and new rigging in place.
