Second SS316 removable forestay to accommodate a hank-on jib on a 1985 Hunter 28.5
Aug 28, 2026
1
Hunter 28.5 Summerland
I bought a H28.5 this week and want to add an additional, removable SS316 for stay, just behind the main forestay, that is fitted with a Furler, to be able to fly a jib in heavier winds, without having to do a sailchange on the furler.
Has anyone ever considered this ?
When the Jib is not in use, the hank-on sail will only be lowered, but not removed, then secured in a bag and the complete second forestay loosened with a quick release mechanism and secured at the side of the mast.
Reason, I sail a lot solo and dislike sail changes on the furler, while underway.
I believe the deck, about 8-10" behind the tack of the main forestay, with reinforcement, can handle the load and stress at that point on the deck.
Not quite sure what needs to be done at the top of the mast, to anchor a second forestay, but I hope I can make up something that transferes most of the load to where the main forestay is attached to.
The furler that this H28.5 is fitted with, is not the original, as this has the genoa halyard internal to the furler tough-luff extrusion, with the halyard secured just above the drum and rotates with the furler unit. perhaps another reason why I am considering a second removable forestay, to fly a jib.
Any thoughts or suggestions. The H28.5 is a double spreader strait and masthead rig.
I often caution folks, especially with new-to-them boats: slow down, wait, become familiar first BEFORE you start making big changes.
Given your description of your gear, it sounds like you have an older CDI furler. I had one when I bought my 1986 C34 in 1998, only 12 years old. For a boat of that size, and yours which isn't that much smaller, those furlers are, ahem, a joke; a toy that would work on a 22 footer, maybe.
Instead of the complications of a second forestay, and IMHO of no need for one with your rig, consider replacing your furler with a new 21st century piece of gear. I replaced that CDI and chose ProFurl because of its built-in wrap stop top swivel. Harken is another great choice.
IIRC, you don't really have a big genoa, you have a huge mainsail and a small working jib. What year is your boat? Am I correct? If so, deal with higher winds by reefing your main. My masthead sloop would "like" to reef the main at 18 knots and on windy SF Bay I ran a summer 85 and winter 110 jib on the furler and never used the furler to reef a jib even though ProFurl supported that. I chose a jib for each season.
Good luck, hope you think this through before you do something unnecessary.
Likes: kloudie1
Nov 6, 2006
10,232
You could also consider a jib with a wire luff so that second halyard could be out of the way when tacking the roller furl sail. The wire luff sets “flying “ so no stay required.
Jan 7, 2011
5,958
Oday 322 East Chicago, IN
Why not just add a furler to the existing main stay, and get a sail that is designed to be furled? The furler means you can reef the head sail to meet wind conditions, no sail changes are needed, and you don’t have to have someone figure out mounting points on the mast and the deck to support a new stay.
I have a 130 Genoa on my O’Day 322 (down from a 150 when I bought her) and find that reefing the headsail allows me to sail in 20-25 knot winds (either reefed main or just headsail). I have been out I. 30 knot winds with just the headsail reefed down.
The furler gives a ton of flexibility without over-complicating the rig.
Catalina 320 Dana Point
I think a decent furler a much better solution as others have mentioned. I regularly furl and unfurl and back again as winds change over the course of the day.
Here is an example of a cutter rig. Is this what you are imagining?
This is a “fractional” rig design. The fore sail does not go to the mast head. There are 2 stays on the foredeck. The inner one is often referred to as a Stay Sail. The design is called cutter rig. The inside stay can be removable.
Your boat is a B&R rig sloop.
The design can be a little difficult to rig a stay sail. The suggestion by @Stu Jackson is a good one. A small jib can be rigged on a more modern furler and used when the conditions dictate. That is how I rig my boat. I have a 95 jib and a 135 Genoa. When conditions get sporty In rig the 95 and find it easy
I don't see why a smaller headsail with a wire luff couldn't be flown from a position aft of the jib furler. I would reenforce the deck with a small stay so you can get halyard tension on the luff of the smaller jib. At least I would want a substantial backing plate. I'd note that on a C&C 25 I used to sail on there was a removable baby stay and it was supported by a wire with a turnbuckle. I don't recall how it was terminated on the hull but it was original so a fitting was probable glassed into the hull during the build. It was standing rigging when it was attached. The stay was detachable because tacks were complicated by its presence. It existed to keep the mast from pumping in seas. So that's different than this but I wouldn't want to tack the larger jib with the smaller in place. The OP would have to go up on the foredeck to rig the smaller jib. So that's something to consider.
As an aside traditionally sail was shortened so the center of effort moved toward the mast for better balance of the sail plan. Furlers kind of broke that rule and we're evidently not going back. So in reality the smaller jib would not be very different from a furled larger jib in regard to the balance.
That is the very reason the idea, while possible, is not advisable. You can see the space provided in the Cutter Rig image (message #6). Even though there are several feet of space, often there is a foredeck crew stationed to assist the genoa through the slot between the forestay and the "baby stay", especially if racing.
Alternatively, some cruisers choose to reef the foresail, tack, and then reset the foresail on the new course. This avoids sending the crew to the foredeck for the course change.
With all this advice, I remind myself, it is his 28ft boat, and if he wants a cutter rig, why not? :biggrin:
Go for it, as it enhances your style of sailing. :beer:
John, because this boat is brand new to him. We do not know what his sailing experience is or has been, but the nature of his question elicited similar responses from multiple contributors. And "new boat syndrome" almost always suggests caution in making major changes until familiarity with the boat is achieved.
Likes: shemandr
I wouldn’t even buy new sails until I had a season or so into the boat. How would you know what you want? Don’t you need to learn the boat’s strengths and weaknesses before making big changes?
I understand if you are buying into a class of known boats with lots of info out there. Even then major mods are restricted.
I know folks who cruise on a J24. A lot different than racing around the buoys on Wednesday nights. Even more different from racing in one design fleets. I don’t think one size fits all works in regard to sails. Yeah class rules specify basic dimensions of a sail. But from there it’s artwork.
