Terminal connectors
Aug 7, 2021
164
O'day 28 Casco Bay
I have used both cheap crimpers and cheap connectors. I found that it's better to use good connectors with cheap (properly adjusted) crimpers, than expensive crimpers with cheap connectors
The Klein Tools Ratcheting Crimper I purchased was certainly not the cheapest, but was recommended by several Field Service Engineers I work with. Colleagues and friends in the trades are my usual go-to source for advice.
Likes: Timm R Oday25
Sep 24, 2018
4,531
Catalina 30 MKIII Chicago
I have the same one. It works well when properly adjusted and with quality connectors. If using cheap connectors, you'll have a high rate of failure. I saw upwards of 50% failure when I pulled on cheap connectors immediately after crimping.
I've since upgraded to the HST crimpers. It's a night and day difference. I can't recall any failures that weren't due to my own negligence.
colemj
Jul 13, 2004
1,075
The Klein tool looks like a double crimper. This is specifically for double crimp terminals. Single crimp terminals should use a different tool like the HST crimper mentioned.
Double crimp terminals should be used on a boat, but few do. Probably because they don't come in heat shrink versions, so require separate heat shrink tube.
Mark
colemj
Jul 13, 2004
1,075
This is a pain.
Agreed, but is probably why they aren't used more. Double crimp terminals are really the best choice for a boat, as they crimp the terminal to the insulation also, which helps with movement and vibration.
To reinforce your opinion, I have a full complement of double crimp terminals and the correct crimper for them, but almost always use single crimp heat shrink terminals. Lost count of the number of times I installed a double crimp and realized I forgot to slip on the heat shrink first.
Still like the double crimp ones for tiny signal wires because of the added support of crimping the insulation.
Mark
